Old 07-06-2012, 04:44 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Originally Posted by ErikLS2 View Post
Current (amps) is the same throughout the entire circuit, meaning both the ground and positive cables need to be the same size (if they're the same length) for it to be right.
I am using #1 cables and the negative is bolted to trunk sheet metal. Is it OK to use 1/0 ground strap between the body and engine and another strap between engine to frame?
72 Camaro RS:SOLD
68 Camaro:
