Old 07-15-2012, 12:52 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by coolwelder62 View Post
Mark,What is the spacer for between the bellhousing and trans.Is the clutch setup thicker than stack.Wiring is extra clean.
The spacer is .850" thick to allow the stack up to be correct to run a LS9 twin disk cllutch in front of a TR6060 with a 2002 style bellhousing. D&D Perfromance made the spacer and sells them.
I'm on the edge on the stock LS9 clucth but it drives great with very low effort and a great feel.
We build all the wiring from scratch. If you start with a GMPP LSA harness it is much easier.
Ryan Kuhlenbeck also wired Red Devil and we used that as a templete for this build.
The VanNus's (Dutchboys Restoration) is starting to shoot color tomorrow so I'm getting closer to getting the car back.
Mark
