Old 07-20-2012, 10:13 PM
FETorino's Avatar
FETorino FETorino is offline
Default Mild side oiler build
If you're into this kind of thing.
Rob in SoCal
Old 07-21-2012, 06:19 AM
I'm certain I saw the valve covers being sucked inward....
WOW!
Old 07-21-2012, 06:55 AM
Rick D's Avatar
Rick D Rick D is offline
WOW!
Yuppp I saw that also!! What kind of numbers did that make?
Rick
Old 07-21-2012, 04:34 PM
fleet's Avatar
fleet fleet is offline
We bought a couple of his 351 Windsor strokers a few years back. I was very impressed by Jim.
Old 07-21-2012, 06:46 PM
FETorino's Avatar
1112hp naturally aspirated. Not bad. The heads on Jims are not standard FE design but rather canted valve billet heads.
Here is another about to hit the dyno being built by Jay Brown with some massaged Blue Thunder castings. Jays High riser may hit 1000hp NA. You can follow his build thread below.
http://fepower.net/simplemachinesfor...?topic=168.210
Rob in SoCal
Old 08-01-2012, 09:25 PM
FETorino's Avatar
Jay is going to run his high riser on the dyno this weekend. If you're a fan of naturally aspirated big hp this thread should be a col read this weekend.
http://fepower.net/simplemachinesfor...?topic=168.225
Rob in SoCal
Old 08-02-2012, 01:04 PM
Mild?
Old 08-02-2012, 03:47 PM
Nessumsar's Avatar
Nessumsar Nessumsar is offline
Originally Posted by ratman67 View Post
im really surprised that he is only thinking he will make 850 ponies with that thing. my bbc 540 pump gas engine made 804 hp, with a single dominator on a single plane intake at 6500rpm...why is it sooo hard to make hp with ford engines. that engine looks like it cost a truck load of money to build
Keep in mind he is making almost 40% more hp/liter than you are. Thats a LOT!
That is a pretty killer engine.
Jon Rasmussen
'72 Nova
Old 08-02-2012, 04:01 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Very cool. What compression?
Old 08-02-2012, 08:23 PM
FETorino's Avatar
i know from the intake up probably cost 10k....
He built the intake himself including all the machine work and design.
He is a multi time drag week winner so two things to keep in mind.
1. He is guessing low on the hp figure.
2. He is going to run pump gas and drive the thing 2500mi for Drag week this year.
Rob in SoCal
