Old 08-07-2012, 10:38 PM
Cole Cole is offline
Banned
Default Manual T56 Troubles
Hey Fella's!
Below are some pictures(not in order) that show my shift fork within a inch of hitting my floor, floor, and trans tunnel.
I forwarded these pictures to "the vendor" and was told that there is nothing they can do. In which they recommended going hydraulic. I was also told that my floor was the problem. Also mentioned was the product fits the car, the car doesn't except the product and the customer service are the only things they can do. Note: I have original floors in the car.
Any Advise???
Old 08-07-2012, 11:09 PM
Banned
few more..
Old 08-08-2012, 12:46 AM
Sieg's Avatar
Sieg Sieg is offline
Appears the tunnel clearance is more than I have, what motor mounts are you using?
Does the arm make contact at any point through the range of travel?
Can you clearance the floor without any negative impact?
Old 08-08-2012, 07:16 AM
Banned
Sbc 383, The arm has 1" of clearance until it hits. What do you mean by negative impact? We would need to rework the side of the tunnel.
Old 08-08-2012, 08:54 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
It would be helpful to know your entire setup - car, current engine, transmission model and mounting used, engine stands, motor mounts, bellhousing and whether a factory clutch pivot or adjustable, and so on. It looks like a '69 Camaro, you said small block, and you're using an adapter plate.
The pictures doen't show a clutch pedal - how far into mockup and testing have you gotten?
Old 08-08-2012, 09:05 AM
Banned
69 Camaro, SBC 383, T56, Xfactor crossmember, Poly Motor & Trans mts, Factory Linkage, Adaptor plate.
Pedals are mounted using a Zbar.
Thanks again.
Cole
Old 08-08-2012, 09:17 AM
Ron in SoCal's Avatar
+ Muncie Bellhousing, right? Need to determine short/tall or low/wide motor mounts...
Ron in SoCal
69 Camaro in progress
Old 08-08-2012, 09:47 AM
Mkelcy's Avatar
Thanks again.
Cole
Man, this is like pulling teeth.
Have you installed the clutch, flywheel, Z bar, linkage, pedals, adjusted everything, fired the engine and determined that there's an issue - i.e., that you can't disengage the clutch and/or get a good clutch pedal release point with things as they are now?
It also looks like the transmission is clocked, as if you had an adapter plate intended for a third gen or have the transmission mounted in the wrong set of holes in the adpater.
Finally, have you checked driveline angles. There appears to be a LOT of room in your transmission tunnel.
Old 08-08-2012, 12:00 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Go hydraulic.
Old 08-08-2012, 12:23 PM
Sieg's Avatar
Negative as in footwell clearance for throttle function.
FWIW - Here's my '69 SBC w/ T-56 Mag.
W/ Moroso solid motor mounts.
I did a fair amount of massaging of the firewall to clearance the QT bellhousing.
