Old 09-03-2012, 08:15 PM
eric36 eric36 is offline
Default 17" Budnik Gasser wheels and tires
I have a set of 17x7 and 17x8 Budnik gasser wheels with tires
5 on 4.75 bolt pattern
Fronts are 17x7 4" Back space
Rears 17x8 4.5" Back Space
Tires are Forceum and are like new
205-50-17
245-45-17
$2000
1969 Chevrolet Camaro
Dse / Marquez / Recaro / Budnik /Nitto
1970 plymouth Gtx
Old 09-04-2012, 07:40 AM
You should probably also post the backspace specs... that will help people make a "fit" choice... and also your location.
Old 09-05-2012, 08:03 PM
Remeasured wheels tonight and If im doing it right the fronts are 17x8 4" backspacing and the rears are 17x9.5 with a 5"
fronts have about a 2.5 " lip and rears have about 3.5
One front wheel has a little bit of curb rash (that could easily be fixed)
1970 plymouth Gtx
Old 09-05-2012, 08:18 PM
I'm hoping you measured wrong, because those offsets will be a problem on most older cars (not enough backspacing to clear the fenders).
Watch this and see if you are measuring correctly.
Old 09-05-2012, 08:22 PM
I measured lip to lip so they look like they are 17x7 and 17x8
Backspacing is still the same
1970 plymouth Gtx
Old 09-06-2012, 07:25 AM
OK, that's better.
Old 09-06-2012, 08:39 AM
Swain's Avatar
Swain Swain is offline
on the back of the wheel, located on the mounting surface their is a work order#.
It has a letter and 4-5 numbers. I can tell you everything about the wheels if you give that to me.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 09-06-2012, 09:10 AM
HRBS's Avatar
HRBS HRBS is offline
Thats customer service !
HRBS on Facebook
Old 09-08-2012, 11:18 AM
Im afraid too see how far i am off on my measurements
I4015
I4016
1970 plymouth Gtx
Old 09-10-2012, 12:49 PM
Swain's Avatar
I4015
I4016
Jason Swain
