  #16
Old 09-13-2012, 07:19 PM
parsonsj parsonsj is offline
Ed, venting a differential is almost the same as a fuel tank except that the hose that connects them needs to articulate throughout the rear suspension movement. Most rear end housings have 1/4" pipe threads and a simple "bobbin" vent that oozes differential fluid. Remove that bobbin vent, screw in a 1/4 to 6AN fitting in its place and connect it to our Vent, and you're good to go. No more oozing fluid on the housing, and no more whiff of differential fluid.
John Parsons
