Old 09-17-2012, 05:34 AM
Amituk's Avatar
Amituk Amituk is offline
There is a good run down on 12s and 9s from jason at the GMR on my thread here
https://lateral-g.net/forums/show...t=37889&page=2
If you already have a 12bolt, I certainly wouldnt worry about it. Not a great deal in it really.
The only real advantage of the 9" that cant easily be replicated into a 12bolt is the easily interchangeable third member allowing easy track side ratio changes.
Amit
Build thread -NightHawk - 69 Camaro supercar build
Facebook -Like ProjectNighthawk
Twitter -@ProjNighthawk
Old 09-17-2012, 06:44 AM
SR71 SR71 is offline
the 9" axles are retained by pressed on bearings instead of c-clips eliminating side to side axle play. thus the 9" doesn't suffer from pad knock back and has positive axle retention in the event of breakage.
if you are going to buy aftermarket axles, moser makes a kit that converts the 12 bolt over to 9" ford style axle retention.
69 ss/rs clone, hugger orange w/wht stripes, 406/ 6spd/12 bolt drivetrain, ridetech tripples, speedtech torque arm, sc&c arms....centerline champ 506's and 275/335 kdw's
98 trans-am...black ram air convertable....firehawk bilstein suspension.
Old 09-17-2012, 08:05 AM
The 9" definitely has pad knock back issues, which is why Mark Stielow and companies like The GMR Co. spent so much time developing ways to eliminate it. Several of our members who track their cars have had issues.
http://thegmr.com/
Old 09-19-2012, 02:53 AM
BigChevyFTW's Avatar
BigChevyFTW BigChevyFTW is offline
Thank all of you for your replies.
The article I read simply said " we ditched the 12 bolt strait line Drag Strip rearend for a Currie 9 inch.
that could have been a marketing ploy from the magazine.
The 12 bolt is like new with 3.73 gears i bought it from a guy who never installed it. only bad thing is the drum brakes so i will be replacing them soon and using the 12 bolt thanks fellas.
Old 09-27-2012, 04:08 PM
David Pozzi's Avatar
On a 12 bolt with limited slip, a new unit will have no axle end play, a worn plate type will have some end play, re-shimming the clutch pack will reduce it. The Ford 9" has a better axle bearing but still has brake knock back problems. The cheapest solution is to use a floating caliper on the rear. If you want to use a fixed caliper, you need to install full floater axles.
David
http://www.PozziRacing.com
Old 09-28-2012, 01:19 AM
David
This guy knows what he's talking about.
Old 09-28-2012, 09:23 AM
AmKenpo1's Avatar
AmKenpo1 AmKenpo1 is offline
The 12 bolt can be built into a great assembly with the only potential issue being the axle retention. I would recommend having the housing end replaced with with an end that accepts a large Ford/Olds style 3.150"O.D. bearing or a floater assembly. There are C-clip Eliminator kits available but you will need to be sure to use one that has a tapered bearing vs the low friction ball bearing type. You've got alot to consider but it seems your getting some good information here.
Wil.
Strange Engineering
Old 09-28-2012, 12:35 AM
Might have already been set up for drag racing ie: spool, numerically high ratio so it was problably a bit cheaper to go with the 9.
