10-08-2012, 06:22 AM
Flap Discs???
So what and where does antone use for flap disc grinding discs?? I have use so many different ones lately but can't find and that either last a descent amount of grinding. I have bought the cheapest sh!t from Harbor Frieght to the most expensive ones from Walter. Yes the cheap is did last very long but the more expensive did last that much more?? So anyone got a good source as to where to find good ones??
Rick
10-08-2012, 08:03 AM
I have found that the expensive ones do not last long enough nor cut that much better to warrant the cost. This is where we buy all our rolocs, flap discs, cut off disks etc.
http://www.lehighvalleyabrasives.com/servlet/StoreFront
You can't beat the cost. The only thing I recommend is pay attention to shipping. It's best to order multiple things to bring the overall shipping cost down. Even with shipping the cost is better.
In a pinch if we run out and we don't have a multiple order, we have a harbor freight store 15 minutes away.
Just my opinion and yes I have tried 3M, Norton, etc along side the others and this is what I found.
Good luck.
10-08-2012, 08:05 AM
This has been a personal conquest for me as well. We go through a ton at my shop, so I am sure some of the larger shops could chime in with more results for us, but here is what I find:
Walter (the orange plastic backed ones) are hands down the best.
- When it is me using them, thats what I use. Unfortunately when it is an employee that doesnt care about what you spent on it, not the case. I find that you can cut the edge down on a piece of metal and the plastic peels off and you get a fresh edge. In your home shop one of these could last a month!
Rhodius, which are a fiber back, last a long time for the price.
- I find these are better for 1/8 and thicker, as they last a long time but tend to make more "heat". you can use one for about a week, but not on sheet metal flush weld dressing. They last long, but the cutting diminishes with the disc.
Merit
- these are cheaper, around 2.50 to 3 a piece, and they cut nice. They dont last a long time, but they cut like new right to the end. I use these for sheet metal weld dressing. Not great for heavy weld grinding, but on sheet metal they cut sharp and quick all the way through. Lasts about a day of intermittent use.
Norton
- I am trying a batch of these next week when I get low on the Merits. I will post results.
For at home stuff, do yourself a favour and just buy Walters. thats my take. If someone else is using the discs and your paying for them, dont use the Walters!
10-08-2012, 08:09 AM
Oh forgot, Fastenal supplies us with all of our shop supplies, but we are starting to switch our abrasives over to our local autobody supplier, as he can be more consistent with the price. Fastenal is great one day, and then they try and sneak a higher price by you the next time they bring a stock up order. I am constantly phoning about it.
I always try and support local. Plus our autobody supplier will hold the inventory for us, and we can jsut buy them in a dozen when we need them! No shipping, etc. Once we start using something, he makes sure he has enough supply so that there is no wait if we run out. And he delivers. so for the 10 cents more per flap disc its totally worth it. Just like ordering parts, sometimes it is detrimental to search for the best price over service and supply!
10-08-2012, 03:27 PM
Klingspor.
The best.
97 Sonoma "NERA": Pile O Sh*t. Literally.
11-06-2012, 01:36 PM
I've had really good luck with the Dewalt flapper wheels and cutoff wheels.
Like you've mentioned I've bought cheap crap thinking it would be the same but they just dont hold up. I've even had some of the cheap cutoff wheels blow apart under normal use.
11-06-2012, 09:28 PM
Home Depot Norton Brand
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
11-06-2012, 10:55 PM
I have used the Norton's quite a bit and am real happy with them. I'm looking forward to Tyler's feedback though, hopefully he'll stop back and give us an update.
I am also curious about what people are using for dressing welds and finishing this off nice and smooth? Seems to me a flap disc would (could) be a bit too aggressive. Are the Roloc's better for dressing welds? At the moment I'm using mostly 1/8" and sheet.
Will Ellis
Project SCUD, 1969 Dodge Dart Swinger, 1/2 Dart / 1/2 Viper
11-07-2012, 05:53 AM
Just curious, what are you guys using flap discs for?
Donny
11-07-2012, 07:09 AM
Aggressive material/steel removal. Then switch to something smaller.
