Old 11-09-2012, 04:15 PM
Bad94 Bad94 is offline
Originally Posted by frojoe View Post
Nova's can only go up to 315 if I avoid cutting into the framerails. 305 for the R888 to start, but if traction is still limited I'll go full 315 with the 555R2.. they seem to be working well for Mark.
So you say a stock nova wheel tub will fiit a 315?
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 11-09-2012, 04:22 PM
frojoe's Avatar
frojoe frojoe is offline
Ryan.. I'm not if I want to cut into the frame rails.. from a thread somewhere that I saw, there had to be significant cutting, to the point of the framerail being less than 1" thick, to fit a 335.
A stock Nova tub will hold a 275 comfortably at my ride height, likely 285 as well if the BS was increased slightly and possibly a higher ride height. From what I've read, up to 315 can fit if the wheelwell tub is widened up to the outboard side of the rear frame rails. To go wider than 315, the tire will interfere with the framerail so the framerail will have to be notched inwards and the tub widened even more so..
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 11-09-2012, 05:34 PM
A 315 wont fit with the stock tub widen to the out side of the framerail.
This is a 305 toyo R888 with DSE tubs as they tell you to install.
And here is a 335/30/18 on a 12" wheel with DSE tubs cut and widened to full 3"
Both of those novas are mine.
Old 11-09-2012, 05:38 PM
Rybar's Avatar
Rybar Rybar is offline
awesome, I was just going to post your thread: http://www.pro-touring.com/showthrea...-project/page4
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 11-09-2012, 05:42 PM
Yeah man... with your skillz... you gotta dial in that 335 rear.
Old 11-09-2012, 05:54 PM
frojoe's Avatar
Bad94... Thanks for that info. On the DSE site it says up to 315 with just their tubs, I wasn't aware that 315 wasn't feasible. This further solidifies my 305 decision I think. It was also your build thread that I was recalling when thinking about how thin the framerail has to be chopped to fit a 335. I'll climb under there this weekend and see how I feel about all this. In exactly those areas that the framerail is notched so much, is where my G-link bracket is welded, so not sure how much I want to cut into that. We'll see...
Joe
Old 11-09-2012, 08:07 PM
frojoe's Avatar
Made my own accessory belt route. Main reason for doing this was so that I could lower the alternator for more hood clearance using what I already had (Gen III truck accessory setup).
Started with some simply measurements of main pulley locations and distances, and moved things around on the computer..
You can see how much clearancing I needed to do to the stock cast alternator/PS pump bracket to lower the alternator..
Backing plate which a new idler location threads into..
Re-used the stock idler puller, but different location. Saved the old idler location for a much smaller pulley with high-speed needle bearings, to clear the throttlebody and intake cold side tubing as well as the inlet for the LS3 waterpump..
Voila.. a more compact, minimal-dollar accessory drive setup..
Joe
Old 11-11-2012, 08:13 AM
MattWash08's Avatar
MattWash08 MattWash08 is offline
Nice build! Ive always been a fan of Nova's and you dont see near as many of them
Matt
1969 mustang fastback
-302,t5, and alot of other plans....
https://lateral-g.net/forums/showthread.php4?t=31687
Old 11-11-2012, 09:45 AM
Bryce Bryce is offline
nice build!
Old 11-11-2012, 03:56 PM
Hey Joe. What do you have planned for the front now? Noticed you had your qa1 setup or sale.
John
'71 Nova (Build thread)
FFR Roadster
