Old 11-25-2012, 08:14 AM
ccracin's Avatar
ccracin ccracin is offline
Default Moving Along!
The hood opens and closes. Go figure!
Now that the hood opens and closes and fits well enough for the bodywork it is time to move forward. The truck now steers with with the sterring wheel for the first time in about 4 years. We put the steering column in and installed the u-joints with DD shaft. We did this is an effort to check the front end for tire clearance. As much as I would like to, the 315-35-20 is not going to work on the front. It is too big in diameter. If this were an all out race truck and we didn't need to worry about inner fenders etc, they would work. In the end this is still a street truck that will have a "finished" look. So, it's on to a 26"-27" tall tire. Here are a couple pics.
Thanks for looking!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 11-25-2012, 09:31 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
That hood gave you the blues, huh? Nonetheless, looking good. I bought a NOS one for mine about 4 years ago and I'm gonna s#!t a brick if I gotta put a whole lot of work into it.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 11-25-2012, 11:42 AM
ccracin's Avatar
I can tell you the work done to get the hood hinges to bolt up was a problem with the fenders and not the hood. If you can find rust free oem, DO IT!
Thanks for the kind words!
Chad
Instagram - @cctek
Old 11-25-2012, 11:48 AM
ccracin's Avatar
Sorry --- Gotta say it..... WAY TOO SMALL
OD or Sidewall?
I think he is leaning toward a change. I think we are sticking with the same O.D., but using a smaller wheel. Now he is thinking a 295-45-18 on the back. Same O.D., but 1" more sidewall. Front will probably be 295-35-18. We'll see. There was a lot of head scratching and math going on last night!
Chad
Instagram - @cctek
Old 01-13-2013, 06:41 PM
ccracin's Avatar
Just wanted to say in this post how nice the Ring Brothers Hinges are so far. After I fixed all the mounting points on the sheet metal, man are these things smooth. They really have a great feel compared to stock. You can also stop the hood wherever you want and it will stay. Check it out.
Chad
Instagram - @cctek
Old 01-13-2013, 06:44 PM
214Chevy's Avatar
Well, I should be safe then because I've got both, left and right, NOS fenders too. Looking good sir. Hood looks good closed and the gaps are on point too.
'68 C10 swb
'72 Chevelle
Old 01-13-2013, 07:04 PM
ccracin's Avatar
Default A Real Update!
It's been a while, but I have done some work. Christmas and New Years took it's toll on progress. I just couldn't pull myself away from my twin girls over the Holidays!
It looks like after more fitting, moving, turning, and measuring that I care to think about we are going with a 26.65" diameter front tire. Most likely a 275-35-19. With this tire size and moving the the front tire up a full 3" and turning full lock it's going to take a custom inner fender well. OF COURSE IT IS! First comes clearancing the inner structure of the fender. Then I started with the stock inner fender for some of the more complicated curvature to save time. I'll then make the rest. Here is the beginnings.
We'll keep plugging away!
Chad
Instagram - @cctek
Old 01-13-2013, 07:54 PM
Chad -- you're a regular master.... (okay I won't finish that the way I wanted to)........ Craftsman!!!
Nice work! It's looking really good!
Old 01-13-2013, 09:17 PM
ohsolowtrent ohsolowtrent is offline
looking good! You better get busy racing season is around the corner.
Old 01-20-2013, 08:20 AM
ccracin's Avatar
I think!
Thanks Trent, I think this season is out. I'd be happy to step into your monster if you need help!
Chad
Instagram - @cctek
