Old 12-07-2012, 12:39 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
It has been a few months since the last update on Brian's 67 Chevelle. We have made a good amount of progress on the build and it is just about ready to head over for body work. Here is a look at what we have been up to on this build.
Started with the bumpers and wanted a cleaner, smoother look with out veering too far off from stock. (At the request of the great Kenny Davis, they will be chrome.) The stock bumpers on these cars fit like.... they were made for a different car. They hang a few inches out past the body and really do not follow the rest of the lines on the car too well. They are tight in some areas and have large gaps in others. They are high in some areas and low in others.
Before:
After: Also start of the new upper bumper to grille filler panel
Also decided to ditch the license plate area and smooth that out to create 2 distinct bumper openings. Again, trying to keep a smoothed stock look.
Another problem with the 66-67 Chevelles is that the bumper is too short and you end up seeing a lot below it. In this case it is the radiator, core support, and dry sump tank. We fabbed a small chin spoiler to conceal everything.
Also had to fab some new bumper brackets to get the bumper tighter to the body, eliminate the bumper bolts, and have clearance to go around the dry sump tank.
www.roadstershop.com
Old 12-07-2012, 12:43 PM
Supporting Vendor
RoadsterShop.com
There was a considerable amount of work required to get it to fit close to the body and follow the lines it should. It was narrowed, raised, and brought in closer to the rear body. The corners were completely re-worked so the peaks were brought inline with the tail lights. Material was also added to maintain a consistent gap from the top of the bumper to the bottom or the car.
Old 12-07-2012, 12:45 PM
Supporting Vendor
RoadsterShop.com
To smooth out the side of the car, the customer chose to eliminate the lock cylinders and use Kindig It's flush mounted smooth door handles
Old 12-07-2012, 01:00 PM
Supporting Vendor
RoadsterShop.com
Also finished up a lot of the smaller jobs to get it ready for the body work phase.
Mounted the Peterson Dry Sump Tank and fabbed stainless upper and lower hoses to the Ron Davis radiator. Working on the cold air intake tube now.
Wrapped up the center console, steering and pedals.
Old 12-07-2012, 01:15 PM
syborg tt's Avatar
Looks like it's time for a Road trip. I need to see some finished cars.
ps We still dropping the 62 off after the first of the year ???
marty-mj
Old 12-07-2012, 04:21 PM
Supporting Vendor
RoadsterShop.com
We are still good for just after the 1st of the year on your Six-Deuce. We should have a certain chassis just about completed at that time....
Old 12-07-2012, 05:56 PM
fleetus macmullitz's Avatar
Great work by the RS crew ...again.
Old 12-08-2012, 09:28 PM
TravisB TravisB is offline
Are you guys back purging your stainless exhaust? Looks really nice
Kenny Davis Hot Rods
Old 12-09-2012, 07:58 AM
Phaeton's Avatar
Phaeton Phaeton is offline
Coming along great. I'll take a set of the bumpers.
1967 Chevillain
https://lateral-g.net/forums/showthread.php4?t=38121
Old 12-09-2012, 09:15 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Unreal! Thats on a whole different level of greatness.
