Old 12-02-2012, 01:32 AM
Big-Head Big-Head is offline
Default Kevin's Mustang
Kevin came to Big Head Motorsports for custom stainless steel header's and bullhorn exhaust. It's a SBF 438" Edelbrock SC1 Glidden head's, F3 Pro Charger and putting out an estimated 2100hp. Should be in the low seven second zone.
Old 12-02-2012, 03:15 PM
Yeah - That'll work!
Nice welding and workmanship as usual!
Old 12-02-2012, 07:56 PM
Yeah that's a serious hp per cube number.
Old 12-02-2012, 08:15 PM
Are you purging when you're welding up the tube to the flange or is it not necessary then??
Old 12-02-2012, 10:07 PM
Wow Sweet!
Old 12-04-2012, 12:04 AM
Greg, it's not necessary. With the primary tube being 16ga you won't have any problem burning through. Just make sure you use .045" filler rod. Anytime I use 18ga material I definitely back purge. Also, if I use a weld on collector I back purge because there is so much heat being placed in one area.
Old 12-04-2012, 11:48 AM
NOPANTS68 NOPANTS68 is offline
Yeah that's some bitchin work. Nice job once again.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 12-11-2012, 02:46 PM
Chassisworks Chassisworks is offline
Supporting Vendor
Nice work, Alex.
Old 12-11-2012, 11:01 PM
Originally Posted by Chassisworks View Post
Nice work, Alex.
Thanks man!
Old 12-15-2012, 08:28 AM
Thanks again!
