Old 12-26-2012, 04:28 PM
usa-69z usa-69z is offline
Default G BAR type Kits available ?,,
i have a 69 camaro which im about to mini tub using dse gear,, I have a couple of questions if anyone can help..?
I have a ricks vapor worx tank in there now to suit my injection setup.. can i keep this with the DSE minitub ? im thinking about a G bar setup instead of rear leaf springs.. What other brands/manufacturers make these g bar suspensions? ive only seen chris alstons but no others.. I want something with not much in the way of cutting etc as my skills are limited..I thought by eliminating the rear leafs i may be able to keep my fuel tank as it is ?
thanx , Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 12-26-2012, 06:10 PM
Musclerodz's Avatar
thanx , Gav
ridetech is bolt in and is basically the same as the version 1 g bar. The new g bar is weld in. other rear setup to look at with minimal welding is speedtech.
you can reuse your tank with 4 link and minitub if it has notched corners to clear exhaust. if you decide to run offset shackles and leafs you will need a narrowed tank
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-26-2012, 08:21 PM
thanks Mike , ill have a look at the ride tech product.. is there a prefered product with these that guys go for more often because of quality ?
best ? art morrison/alston/ridetech/speedtech
Old 12-26-2012, 08:38 PM
Musclerodz's Avatar
preferred Ridetech part or preferred brand?
Mike Redpath
facebook page
Old 12-26-2012, 09:59 PM
Rybar's Avatar
Rybar Rybar is offline
Gav, I have an Alston G-link with a standard width non-notched tank. it can work with custom tailpipes.
Ryan
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 12-27-2012, 01:29 AM
Ryan
ah' thats what i was after .. thanx Ryan ! also have read here that with the mini tubs the shock location is tight with wheel backspace,, any truth in that?
how much did you narrow your diff etc.. Im just trying to work out what im up against , is there any hidden extras im missing before i start the teardown?
ps. i hope you had a great xmas and have a awsum new year !
Gav
Old 12-27-2012, 01:31 AM
Mike , i was thinking brand.. as in quality and ease of fitment.. pick of the bunch
Gav
Old 12-27-2012, 09:18 AM
garymac69's Avatar
garymac69 garymac69 is offline
Default Ridetech
The Ridetech 4 link was a pretty easy install. It can be a bolt-in, but I got a friend to also weld mine in. I have a stock gas tank and have 2 1/2 in. tailpipes routed out the back. I also have a stock-width 12-Bolt rearend on my car. Narrowing the rear is an option only if you have to have the deep 6" wheel lip look. My lips are 4" and look OK to me (and this setup cost me less $$). You could get your rear wheels widened 2 inches to the inside and it would work perfectly. I was originally going to get my 18x10's widened, but someone locally gave me a great price on those wheels & tires.
BTW...I love your stack fuel injection setup and would like to someday get one for my '69. How about some pics?
Gary
'69 Camaro - 427 SBC 526hp,593 ft-lbs, Tremec TKO, Ridetech Coilover Suspension w/TruTurn, Billet-Specialties Draft 18x9, 18x12, BFG KDW 275/335
Old 12-27-2012, 09:41 AM
Rybar's Avatar
Gav, just be careful if you get the Alston G-link alot of people had issues getting the correct ride height sorted. The kit needed some slight modifications like shorter springs or some parts they released after to help with this. Just research it before you buy. Also, I think my Moser rear is 54.5" or 55" wide. And my rear wheels are 12" wide with 5.375" BS
1969 CAMARO RS
Old 12-27-2012, 09:44 AM
Gary
Looks sharp, Gary.
