Old 12-30-2012, 01:50 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Default Best Fuel Resistant Silicone Sealer??
Hey guys,
Im getting ready to finish up my EFI fuel tank conversion and will be needing to seal the top portion of the tank. What is the best silicone sealer to use that is completely fuel resistant. I want to make sure I dont get any vapors or liquid fuel leaking out. Any info is greatly appreciated.
This is what Im sealing;
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 12-30-2012, 03:31 PM
ccracin's Avatar
ccracin ccracin is offline
Brian,
The proper way is to weld it completely and then pressure check it. Relying on sealers for this application to me is not the way to go. JMO Good luck!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 12-30-2012, 03:48 PM
70TWO NOVA's Avatar
Talking
Unfortunately if I weld it shut I won'tt be able to remove the pump when it goes out. I saw them do It this way in PHR but they were sealing It then using fasteners around the edge to keep it tight and in place
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 12-30-2012, 05:06 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
If you're just using it to seal two pieces that already have a tight fit, Brett at Fab53 clued me into "high temp thread sealant." we used it on my gas tank where the cork gasket used to be on the fuel level sending unit. Stuff works great.
Old 12-30-2012, 05:56 PM
ccracin's Avatar
Sorry Brian, missed the application. Thought you had access another way. You will still need some sort of mechanical fasteners. Try searching the permatex or henkel websites. They have compatibility charts to work from.
Chad
Instagram - @cctek
Old 12-30-2012, 06:06 PM
Musclerodz's Avatar
MIL 8802-B1/2. it is aircraft fuel tank sealant and it used for making wet cells in aluminum wing construction.
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-30-2012, 06:45 PM
ccracin's Avatar
Good info Mike!
Chad
Instagram - @cctek
Old 12-30-2012, 10:32 PM
70TWO NOVA's Avatar
Awesome! I'll definitely look more into this. Sounds like a good long term seal. Thanks again guys for all the info!
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 12-31-2012, 10:11 AM
I'd make a gasket for it due to servicability. The sender application should have a gasket available? The pump will likely break when you're 300 miles from home, how do you plan to reseal it in that situation?
Old 12-31-2012, 01:01 PM
70TWO NOVA's Avatar
Well the plan in that situation is to call good ol AAA. I dont plan to carry a spare pump around with me anyway lol
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
