I like how your paint booth is the hood of a 1st gen Camaro!
Love the build though. Such a cool car for Dad! I've had dreams of building a car for my Dad...but his dream car is a 55 Chevy. Quite a bit more expensive than a Camaro.
Yeah, I figure since I dont have the time or money to build my Camaro I might as well put it to some use. Fortunately for me my Dads 80 Camaro isn't exactly a pricey muscle car
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Got the inlet tube soldered in and the pump wires run through the bulkhead. also had to alter the fuel pump sender to fit correctly into the baffle. Now I just need to find a good fuel resistant sealer to seal it all up.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
You've got a grommet on those wires running through the metal, right? I'd redo that set up even if you do have a grommet on the wires. Way too risky being right there with the fuel vapors. They make bulkheads with threads on both side and with a rubber seal. That's the way you need to go about wiring the fuel pump. The ground can just connect to the fuel tank itself or run another bulkhead and run the wire to the frame near by.
I was wanting to run those bulkhead connectors for the pump wiring but I could not find anything. I even posted up a thread on here but nobody could help me find anything. If you happen to know where I could get them Id really appreciate the info. Thats really how I wanted to do this in the first place.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Now that you mention it, I remember that thread. I have no idea where to get something like that though. Maybe McMaster Carr? You might be able to make it using a small grommet that'll let a bolt bass through. You'd have to seal the bolt to the grommet though. Maybe use the sealant you'll use on the tank cover. Use washers on either side of the grommet and it should seal together when tightened down.
