Old 12-30-2012, 12:29 AM
Rybar's Avatar
Rybar Rybar is offline
Gav, the ridetech setup might enable you to sit lower for ride height but may have tighter clearance for the tailpipes. You should be able to weld in the ridetech setup.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 01-02-2013, 05:36 PM
Chassisworks Chassisworks is offline
Supporting Vendor
Gav,
I would be happy to answer any questions that you may have about installation of our g-Bar and g-Link systems. There are a bunch of different options so we can tailor the system to your specific needs. Shock to tire clearance, which someone mentioned, is not an issue. I know you already found the instructions, but did you find this page yet? There are downloads for individual components with lots of technical info.
As far as ride height goes there is no one system that will allow the car to sit lower than any other without modifying the floor. The floor is the limit. We like our cars to handle and ride nice so our baselines specs keep the hard parts from beating each other up. You can read about ride height and how it is determined in this document: Click Here.
Our system is really easy to install and requires minimal fabrication skills. We ship to Australia all the time and we even offer a right hand drive version of our front clip.
Again, I'm happy to answer any questions. My direct extension is 247 or you can email me.
Old 01-03-2013, 11:41 AM
frojoe's Avatar
frojoe frojoe is offline
Originally Posted by usa-69z View Post
another question,, i have had a good read thru both the 'ridetech' and the 'alston g-link' setups.. I did notice alston has an upgrade to be compatible with 'mini tubs' which takes it to $2100 ... i see no mention of any problems with mini tubbed cars on the ridetech site..its around $1800 with decent coilovers.. is this something that i should be mindful of if i went for the ridetech setup? Im trying to save a buck if i can as i have to ship these heavy parts downunder which will cost close to a grand for shipping id expect.
Gav
Because the Ridetech setup uses full-width bushings that appear to put the link centered in the leaf spring pocket, but the Glink setup has a separate insert that fits into the link's forward bearing, so for a mini-tubbed setup, you can buy offset bearing inserts to move the bearing (and thus link) inboard. Nice setup..
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 01-03-2013, 11:58 AM
Supporting Vendor
Our set up does in fact use a full length bushing in the stock front leaf perch. However, the bars are welded offset to the inside. They clear a 335 tire, no problem (use the search and you'll see a ton of posts about this).
Skunk Werks
Ridetech
www.ridetech.com
Old 01-03-2013, 04:24 PM
frojoe's Avatar
Oh snap! Nevermind then!
Joe
Old 01-06-2013, 05:26 AM
usa-69z usa-69z is offline
thanx guys for the input with this.. all these systems would do what im looking for ..It will probably come down to ease of fitment and shipping costs and who can set me up with the best deal . my car will be getting the tubs shortly (waiting on parts ) ,, i want to retain my vaporworx fuel tank and hopefully keep my custom exhaust , but we'll wait n see with that. Im really looking foward to getting stuck in to this next phase with my car..and getting some decent meat under the rear,,
Gav
Downunder
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 01-06-2013, 06:36 AM
makoshark makoshark is offline
Matt's Classic Bowties will take care of you. Tell them your from lat-g and they will give you a special price with shipping costs included.
Old 01-08-2013, 10:28 PM
Ive sent them an email , and am waiting on a response ???
Old 01-08-2013, 10:30 PM
could you give me a part no please for the ridetech setup i be needn' ?
suit minitub,335 tyre 18x12 inch rim.. 69 camaro
thanx, Gav
Old 01-09-2013, 04:14 PM
Supporting Vendor
Gav,
There are a few options you need to choose, so please go to our website and make your selections.
Here's the link to the 1st gen Camaro page (in case you need coil overs as well):
http://www.ridetech.com/store/muscle...hash=V264.V328
Skunk Werks
Ridetech
www.ridetech.com
