Old 01-04-2013, 08:57 AM
parsonsj parsonsj is offline
Originally Posted by Mark
I have less data on the trans but while I'm at it I add one. If someone is not going 10/10ths then the extra cooler are not needed.
I overheat the transmission in my Z06 in about 15 minutes (Sebring, Homestead). It's the current limiting factor on my car on track days. Packaging the coolers are hard to do, but they are absolutely required.
John Parsons
Old 01-04-2013, 03:24 PM
preston preston is offline
When you quote your oil temps where are you measuring it - before or after it enters the engine ?
Are you water/oil coolers plumbed to the cold or hot side of the radiator ?
What is your airflow path for the rear mounted coolers ? I have mounted them in the tail panel before that seems like a low pressure area but I have heard you can actually get reversed air flow in there if you have a somewhat "open" trunk like I do. Where do you pick up your intake air for rear mounted coolers ?
Old 01-05-2013, 07:06 PM
Stielow's Avatar
Stielow Stielow is offline
I finally got the Anvil parts.
The fenders, inner fender wells, front valance, and hood saves approx. 125 lbs.
I can also fit a 11 inch wide front wheel!
Nice well made parts that fit well.
Mark
Old 01-05-2013, 07:13 PM
Okay -- so how you going to work that in the paint scheme! No friggin' way you can cover those parts up!!
Old 01-05-2013, 07:17 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Old 01-05-2013, 07:18 PM
camcojb camcojb is online now
Mark
told 'ya!
Old 01-05-2013, 07:32 PM
Stielow's Avatar
Matt has the exhaust cut outs done
The carbon rear bumper is crazy light. Looks cool also.
Old 01-05-2013, 07:35 PM
badmatt's Avatar
badmatt badmatt is offline
Mark, I say you paint this one a super dark grey, leave the front end bare and tint the clear coat to make it subtle...
Just a thought..
Matt
Oh and the discussion in this thread is worth a lot of money to some students.
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 01-05-2013, 08:20 PM
fleetus macmullitz's Avatar
Mark
Have them Dutch Boys make it look like metal and everyone here will keep the weight savings a secret.
Old 01-05-2013, 08:29 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
I was @ Anvil last week & saw this parts in person.. Super light! Nice to see them fit up on a car.. What size of tire will you be able to run on the front?
Cris Gonzalez
