Here are a few more idea pictures.
I replaced the ugly factory radiator hose with something more aesthetically pleasing.
I got this idea from Rogers 68 Camaro build. I recreated the water vapor line with XRP AN braided lines and fittings. The hose end that comes off the T fitting would go to the radiator but I'm redoing it. I'm welding a -3 90 degree fitting to the aluminum radiator tube to connect it there.
I dremel down the injector connectors and got rid of all the fat that wasn't necessary for good clamping.
I covered them with a 90 degree heat shrink boot to get a cleaner look.
At one point, I was going to run individual hard lines to each injector. You can see the AN injector hat on top of the rear left injector.
But I looking to replace this intake. So I'm not looking to do any more R&D on it.
This is a cool idea which I haven't seen anybody do. Perhaps somebody here can take advantage and implement it on their own project.
