Old 01-11-2013, 09:07 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Default CAC mini tubs Gen II Camaro
Is there any difference between Chassis Works and the DSE tubs for the Gen II Camaro application?
I was recently told I would need to modify the frame rails to fit my 335's. I have been searching and havent found a detailed thread on a Gen II install. I have followed several threads with mini tubs and never saw anything about a frame rail mod, is it needed? Kind of on a time crunch, I appreciate any help. Thanks Kevin
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 01-11-2013, 07:22 PM
32deucecoupe's Avatar
32deucecoupe 32deucecoupe is offline
here is a link to first gen mini-tub, not sure about second gen but this was the most complete thread I have ever come across.
http://www.pro-touring.com/showthrea...a-68-69-Camaro
here is another that is for a 70-81 camaro from carcraft..It does look like cutting will be required..
http://www.carcraft.com/howto/ccrp_0...t/viewall.html
Old 01-12-2013, 09:34 AM
KPC67's Avatar
KPC67 KPC67 is offline
The car craft link is has some pretty good pictures.
for the tubs themselves I don't think you have to cut the frame, the frame only needs to be cut along the bottom for the leaf spring to be moved inward.
Kevin Carter
Old 01-12-2013, 04:13 PM
After looking at it again I believe you are right, be nice if first Gens were the same..
Old 01-12-2013, 04:43 PM
NorCal72's Avatar
I should have added I wont be useing leaf's, I would be going with a g link setup. Thanks for the input guys.
