Old 02-05-2013, 04:03 PM
carbuff's Avatar
carbuff carbuff is offline
Originally Posted by Cris@JCG View Post
I have broke one WaveTrac... Sent it back never got an answer on why.. I moved on.. Ran Tru Trac... Still lighting up my inside tire.. OS Giken.. did work either...
I finally found one that work for Blu Balz! But if I tell you guys ... you will never believe me... I chased the probelm for months...
Cris,
I don't suppose it would be related to the following post from May of last year on Blu Balz, would it? I was looking for some followup info at the time, anything you care to share?
https://lateral-g.net/forums/show...postcount=1035
The one thing that we have not been able to keep from losing in the car was ring & pinions.. Discussed this with Kyle @ DSE & this is what we came up with as a solution… Heat has been our enemy.. but @ the time upgrade to something that is more for racing purposes…
C&R Racing has introduced current NASCAR Ford 9” technology for the Pro-Touring and Track Day customers. Starting with an investment cast nodular housing that is almost 8 pounds lighter than a standard case. Ring & Pinions are ISF® Process (Isotropic Superfinish Process) by REM Chemicals for reductions in friction, heat build up , power loss, noise and increases longevity. C&R also utilizes our in house 9” Dyno which measures heat, hot & cold rolling torque , final backlash and is checked for noise. It also allows us to ship 9” already broken-in so it is ready to run when you receive it.
Old 02-05-2013, 11:47 PM
^^ That C&R piece is top of the line but very very spendy. You could get 3 or 4 True Tracs for the price of one of those, but I guess if ya keep breaking True Tracs, etc....
I am waiting to see what you buy and get the opposite
Is this George Costanza "Do The Opposite" Day for you?
I'd go wave trac just because it has a great warranty.
So does the Quaife. And I agree with Chris's research below as well. That thing has its own issues too.
Originally Posted by chr2002ca View Post
I went with the 33-spline Tru Trac. WaveTrac's have got their own issues also. Do your research and you'll see. Hasn't BlueBalz been through 2 of them already? Doesn't really matter what you buy, plan on replacing it eventually if you're racing. Nothing streetable is going to hold up long-term with the forces these cars are now placing on them with the big HP numbers and wide+sticky tires.
That's one thing I like about the Quaife (and it's a couple hundred cheaper than the Wave Trac) is if it does break, there are great reports of their warranty.
Originally Posted by Bryce View Post
I think they would be better on larger radius turns than tight autocrosses. Less tire speed differential between inside and outside tires.
I keep seeing reports of more people liking it for autocross vs the the road course. I guess I'll never know until I try it.
Right now I gotta say I am leaning toward tryin the Quaife.
