For LSx swaps you can also run truck manifolds flipped forward (reverse the side they came on).  If you need more clearance cut off the 3 bolt flanges and weld on Vbands.  2.25" crossover will support over 1500hp.  2.5" crossover will flow 2000hp with truck manifolds.  The Ohio Boys who ran a built LS2 single turbo went 200mph in the 1/4 mile running truck manifolds in a 4th gen Fbody full weight.
CCW 18x11 front 315/30/18's and 18x12.5 rear on 335/30/18 RA1's,  2850lbs
