Old 04-13-2013, 07:57 AM
69x22's Avatar
69x22 69x22 is offline
Default Hydra dipping
I wanted to give my engine compartment a bit of a face lift so after seeing some parts that had been hydra dipped I decided to try it. This is how it came out. Let me know what you think.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 04-13-2013, 10:15 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by ratman67 View Post
what is that coating? anoziding or plastic?? looks pretty cool, how will it wear?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 04-13-2013, 11:40 AM
Iamtheonlyreal1 Iamtheonlyreal1 is offline
Banned
Very Very Cool... Did you get some sort of home kit to do those pieces?
Old 04-13-2013, 11:52 AM
69x22's Avatar
I had a guy do all 4 pieces for $250. He ground the intake smooth then used a high build primer to get it slick after that was done he sprayed the base coat, dipped it in the CF print then sprayed everything with a few coats of clear.
It is good to 250 degrees. The guy that did it showed me a LS intake that he did on his Camaro 3 years ago and it still looked nice.
1957 Chevy 454LSX
Old 04-13-2013, 02:06 PM
66fury's Avatar
66fury 66fury is offline
I like it.isn't technology cool.!!
Old 04-13-2013, 02:15 PM
Looks good to me!
Old 04-13-2013, 03:45 PM
Rybar's Avatar
Rybar Rybar is offline
I like it. Can it only be done on metal or can it be done to plastic as well?
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-13-2013, 05:55 PM
214Chevy's Avatar
It can be done on plastic too Ryan. Lot's of guys are doing their LS intakes.
'68 C10 swb
'72 Chevelle
Old 04-13-2013, 07:09 PM
headcase headcase is offline
Am I seeing things or is that a carbon fibre manifold? Very nice!
Old 04-14-2013, 07:31 AM
MattO MattO is offline
You're seeing things George
This process has been around for a while. almost any pattern can be printed. I've seen $100 bills, true fire, skulls, entire murals, and yes, carbon fiber. This process works on almost any paintable parts with some exceptions due to the shape of the part. Parts that are completely round do not do well when dipped.
It is a fairly simple process and the finish is slightly more durable than paint I dare to say. What's also really nice is that in a set of skilled hands, not only can more complex pieces be done, but the process is totally repeatable because the print is done via a computer printer. Therefore, if you have some large, complex combination of fire and skulls, or rainclouds made of $100 bills, whatever, the exact same image can be transferred to any desired part without the masking and additional time of air brushing.
I have alot of friends who can do this process and are fairly skilled at doing it. Meclec Metal Finishing in Fresno is very good and you can often find them doing guns and alot of car parts.
"I should have just started smoking crack. Its just as addicting and WAY cheaper..." --unknown
