Old 05-07-2013, 03:06 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Ah hell - I am not on here for a few days, and you go and put more car porn on here!
Looking great!
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 05-07-2013, 03:16 PM
frojoe's Avatar
frojoe frojoe is offline
I hit the subscribe button so hard I think I almost broke my mouse.
You had me at *that shelving full for awesome calipers*
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 05-07-2013, 07:26 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Originally Posted by Payton King View Post
the car being street legal. Here is the AP Racing NASCAR pedal box I picked up. Per NASCAR rules the masters must be on the firewall and not in the car and the brake pedal must be steel. This system is the only one I know of that takes a pull type master. The "cage" holds one end of the master and the pedal pulls the rod...No side load with this set-up that can happen with a push type master.
Holy Billet Brackets, Batman
Geesh there's a lot of machining in those
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 05-07-2013, 07:35 PM
Jr's Avatar
Jr Jr is offline
Killer build! I look forward to more updates
Old 05-07-2013, 10:50 PM
FETorino's Avatar
FETorino FETorino is offline
.043, .043, 3.0. Gold top, Napier second, Stainless Steel third. Total Seal. A solid 20 inches of vacuum...quote per Ed
I will be running a 5 stage pump and yes I am doing the valve covers with the spring oilers.
Pretty impressive stuff
Ed is a big Ford guy since he worked for Roush and actually thinks the Ford D3 motor is a little better than the SB2 due to the exhaust port. He has 3 or 4 sets of heads in his shop now...that D3 would be perfect for that little yellow mustang.
That Ed sounds like a smart guy.
Originally Posted by 57hemicuda View Post
Or a big blue one.LOL
Hm I like Ron's car but if that happened I wouldn't be ashamed to
Rob in SoCal
Old 05-09-2013, 09:43 AM
Payton King's Avatar
Default cage build
I have tons of pics of the cage construction, but they all seem to look the same after a while. Will try to pick and choose to give someone an idea of what is going on. Cage, when completed, will be NASA certified with a log book. I do not plan on going wheel to wheel racing, but you never know...I also have young kids, so I want to be as safe as possible.
Old 05-09-2013, 09:45 AM
Default More
Door bar
Old 05-09-2013, 09:55 AM
Default Pulling the body back off
Old 05-09-2013, 10:01 AM
Default Body off the frame
Old 05-09-2013, 10:07 AM
Default YOu can see from the last photo
posted and the following, Jake put the frame back into the jig to finish welding the cage so the frame does not move.
