Old 05-15-2013, 05:34 PM
Sweet parts there DG!!
I like the advice about the single pick up and the surge can --- that's good stuff to know!
But all this talk about full bladders.... well.... I'll be right back!
Old 05-15-2013, 05:36 PM
I'm running an 8 gallon to save weight.......I think I should be fine.
The Muttstang uses between 9 and 10 gallons in a 20 minute session there bucko!!!
Either you need some more motor.... or you may be getting pushed/towed in a lot????????????
Old 05-15-2013, 05:42 PM
Track Junky's Avatar
That thing is a pig......I only use 5
Gaetano Cosentino
Old 05-15-2013, 05:59 PM
Your right, it does have two outlets.....
Gaetano Cosentino
Old 05-15-2013, 06:20 PM
Fords are like that.....
Old 05-15-2013, 07:21 PM
intocarss's Avatar
That's throtte control!! Smooth on smooth off
Old 05-15-2013, 08:37 PM
89 RS's Avatar
89 RS 89 RS is online now
Good stuff going on Dave, that ATL fuel cell is killer.
Corey
1989 Camaro RS
Old 05-15-2013, 11:10 PM
Full throttle occasionally would alleviate that excellent laps per gallon issue you seem to be having.
Yup. Either dual fuel pumps for you or...
http://www.racerpartswholesale.com/p...ATLAccessories
Thanks Corey. Good to see you around.
Old 05-16-2013, 07:07 AM
Sieg's Avatar
Sieg Sieg is offline
Maybe a booster seat would allow full throttle depression?
Old 05-16-2013, 02:08 PM
intocarss's Avatar
Can We Please Get A Moderator To Lock This Thread Asap!! Thank You
