Old 06-13-2013, 02:34 PM
Iamtheonlyreal1 Iamtheonlyreal1 is offline
Banned
Default LS Engine Coil Relocation Idea, Will it work?
I am really wanting to hide the coil packs on my build, and thought about relocating them to the inner firewall, but I would like to find a closer place to do it.. I have this little pocket in my crossmember kit, along with a unibody frame rail relief for the oem upper a-frame, so it makes a nice little pocket.. I understand that there would be potential water during rains and ect, but these coils are pretty well water proof from what I understand, with the exception of the actual power/signal plug and plug wire, which I am sure can be dealt with..
There should be enough fresh air, along with actual header air gap clearance to run fairly cool, so I am not sure if that would be a major factor at all. I am thinking they would actually run cooler than being trapped in the engine bay air space, while mounted to the valve covers.. Just wondering what some of your thoughts might be, and if anyone has mounted the coils more in the open elements?
Here are some earlier Header Clearance pics of the same area.. I was thinking just a basic rubber style dust flap might do the trick?
Old 06-13-2013, 06:11 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
How much clearance do you have between the firewall and the back of the heads.
If you have enough room then you should get a set of these.
http://www.automotivedesigneng.com/p...coil_pack.html
more pics here
https://www.facebook.com/media/set/?...9836708&type=3
1969 Camaro LS2/T56 D1SC
Old 06-13-2013, 06:38 PM
Banned
Those are pretty cool, but I dont really have that much room, but it does give me an idea.. I have way more room at the back of the block/bell housing area, so I might be able to mount them more center in the rear.
Old 06-13-2013, 07:11 PM
boostin05blacks boostin05blacks is offline
I have some pictures in my build thread of where I placed mine...
Starting on page 18...
https://lateral-g.net/forums/show...hlight=lsx+454
Old 06-13-2013, 07:21 PM
Banned
It appears that you would also recieve some road moisture, have you driven the car yet, or in normal elements?
