View Poll Results: 2 Dynos one winner Big Block Ford vs SB2
Sideoiler Makes the most peak hp 2 4.44%
SB2 Makes the most peak hp 18 40.00%
Sideoiler has the best average hp and tq (3500 to 7000) 12 26.67%
SB2 has the best average hp and tq (3500 to 7000) 13 28.89%
Voters: 45. You may not vote on this poll
Old 07-06-2013, 12:40 AM
Originally Posted by dolf View Post
I wanna play!
437sbc, Dart aluminum block , est. 11.5/1, for pump 93
400+ cfm RFD 15* heads
Ported Mopar 5007420 single plane
Holley 950 ultra, may upgrade to a Braswell or Prosystems with road race floats
Solid roller custom spec'd by my builder
Callies lightweight rotating ass, Diamond pistons, Morel lifters, Jesel pro Series, Blah, blah blah
Should be on the dyno in Dec. Hoping for close to 800hp, 650tq
Dolf -- I'd like to hear about your numbers.
Placed my order for personalized licensed plates.
Thought I just bring this little gem back up top.
Old 07-06-2013, 08:51 AM
FETorino's Avatar
FETorino FETorino is offline
Man... you guys shoulda seen me gettin bossed around the kitchen today..
Happy Turkey Day fellerz. Rob won't be thankful he owns a FE motor for very much longer.
DG was this the gem you meant? Turkey day is that what we call the 4th of July?
Since this is a pro touring site. How about between 3500 and 7000 or a specific rpm value over peak hp down say 3000-3500 rpm. 2500 rpm is peaky for autocross, speed stop, and street.
That is what Dave and I agreed on. I have to take my 3500-4500 data from one of my initial out of tune gas runs and add it to my final E85 pull. This should give DG a better chance at the avg game. He will still fail.
We ran a couple ease in runs from 3000 to 5 and 5500 but there is no reason to be hard on the dyno and run from 3k to 7200 so we did our tuning runs from 4500 to 7200 so that is the data I have.
Hey I'll piece in the runs from 3000 to 4500 with the rich jetting and 4 deg of timing pulled out of it to the 4500 to 7200 runs. It was still making plenty of motivation down low on the insurance tune.
3000 559.6 319.7
3100 567.4 334.9
3200 566.0 344.8
3300 564.3 354.6
3400 577.8 374.1
3500 579.6 386.2
3600 582.3 399.1
3700 587.4 413.8
3800 598.6 433.1
3900 599.8 445.4
4000 604.3 460.3
4100 595.7 465.0
4200 592.4 473.8
4300 591.3 484.1
4400 590.9 495.0
4500 596.5 511.1
SuperFlow
Here you go DG. Throw it in a spreadsheet to see what avg #s you have to pull next year when you get that SB2 on the dyno. Man I wish I had a good pull in tune for that first 1000 rpm. Look at the difference at 4500 Oh well it will get the job done.
3500 579.6 386.2
3600 582.3 399.1
3700 587.4 413.8
3800 598.6 433.1
3900 599.8 445.4
4000 604.3 460.3
4100 595.7 465.0
4200 592.4 473.8
4300 591.3 484.1
4400 590.9 495.0
4500 635.3 547.2 596.5 511.1
4600 636.7 557.6
4700 638.9 571.6
4800 640.0 584.8
4900 641.7 598.6
5000 637.7 607.1
5100 636.0 617.6
5200 632.5 626.2
5300 628.3 634.0
5400 623.3 640.9
5500 625.2 654.7
5600 623.6 664.9
5700 619.9 672.8
5800 612.9 676.7
5900 608.8 683.8
6000 600.4 685.9
6100 594.3 690.3
6200 589.1 695.5
6300 582.1 698.2
6400 575.1 700.7
6500 563.1 696.8
6600 553.3 695.3
6700 542.2 691.6
6800 529.2 685.1
6900 518.1 681.2
7000 508.5 676.7
Rob in SoCal
Old 07-07-2013, 02:21 PM
Do you two realize how many trips I've completed while you're still arguing over which motor is going to blow up first?
Old 07-07-2013, 03:08 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Assuming Dave's engine survives being built and dyno'd, wouldn't these guys need running, driving cars to argue about which motor is going to blow up first?
Old 07-07-2013, 04:31 PM
Sieg's Avatar
Sieg Sieg is offline
There ya go spotlighting the obvious.
Hopefully I get to see a side by side drag race before I die.
Old 07-07-2013, 11:11 PM
If these two cars ever end up running, let alone at the same event, it will be some type of "real" miracle.
Old 07-08-2013, 12:47 AM
At this point I cannot even argue with you fockers.....
