Old 07-06-2013, 05:47 PM
sleepertime's Avatar
sleepertime sleepertime is offline
Smile
You might want to post a few pictures of what the exact problem is, chances are some one has run across a solution. I don't believe that there is an off the shelf solution as to what you are referring to. It may require you to pull the back glass out and space it up or down depending on what you are trying to fix.
