Originally Posted by DaleTx
Looks great Mark... I am wondering how much weight savings with the carbon fiber parts on the front.
Look forward to more pictures on the build and info on the dry sump system install. The front spoiler looks great!
The delta between all the steel parts (Hood, Fenders, Inner Fenders, Header, Cowl, Lower Vance with Bumper) was 122 lbs. Some weight will need to be added back to reinforce the grill and bumper. The parts fit better than I though they would. Also then it is all bolted together the stuff feels very stiff.
Originally Posted by Matt.A
Hey Mark, how is the fit with the 315s? I bought a set of Anvil's fenders recently and I'm curious if you're happy with how the wheel and tire sits, or if you needed to add a little more backspace, or trim the inside of the fender lip to get the wheel and tire to turn without issue.
thanks,
Matt
I have a 18 X 11 mocked up on the front with a PSII 315/30R18. It fits OK but it needs more backspacing than I like to maintain turning radius. I'm concerned with too much tire rubbing. All my previous projects has a lot of tire rubbing and the steel parts just lost their paint. This CF parts will most likely wear away. My plan is to add steering stops and try the 18 X 11 with 7 inch back spacing. The problem is the AutoXs with the 180 degree turns. Also with AutoX like Holley Fest where there is a big bump in a very sharp turn could junk a fender. The steel parts could take a lot of abuse. Unsure on this CF stuff durability. I really like the parts and think I can make it all work.
Mark
