Old 06-27-2006, 04:42 AM
evilzee28 evilzee28 is offline
Originally Posted by 71Nova
The wheels that are on Penny in the picture are smaller diameter than the wheels that are going to be on the car. My guess is that those wheels are just for moving Penny around while work is being done to her.
I figured that they were smaller diameter for rolling the car at this stage, but if you sight where the bottom of the bracket is in the pic it's very marginal even with larger dia tyres. It might well be the angle of the pic, but still worth making sure it's ok. If you do have to run larger diameter tyres with that set up to avoid the bracketry being below the scrub line, then it's a dangerous bit of kit & potential purchasers should be made aware by the company that manufactured it that it requires larger dia wheels/tyres to work safely. Is it that the brackets are temporary & supporting the cars weight in place of the coilovers?? Even if this is the case, the bolt still looks too low.hth Please tell me I'm wrong
