Old 10-29-2013, 09:00 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
great choice I really like the wheels,this project sure is moving along nicely,well done
Old 10-29-2013, 11:39 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Originally Posted by turnhard View Post
If you are reusing the hose from the rearend to the hard line they rust up on the inside of the bulkhead. Kevin
Kev.......Everything is new.......
Ken
Old 10-29-2013, 07:52 PM
kwhizz's Avatar
Two steps forward today........So......While waiting for my Princess to come home to help with Bleeding the brakes......I decided to wrap up another loose end.......I bought an American Autowire custom wire kit and needed to get in the trunk and get the rear harness in......along with the Dakota Digital LED tail lights.......Got everything installed and hooked up......the back of the car is now finished.......Checked on the Rick's Vaporworx Stainless tank and it is supposed to be shipping this week.......Now........Getting back to the brake issue.......
I was taking the easy way out and bled the fronts first as I could do that somewhat easily as the steering column is still out so I could reach thru the firewall and work the brake pedal to get at least a partial pedal by doing the drivers side first....Absolutely wrong ....but by convienence I did it that way......So......I was told to do the rears first......Duhhhh!!!!........So....I removed the front brake line and installed the bench bleeder in the front chamber....when she got home we started bleeding the rears...........Nothing.....no pedal.....just a few drops of fluid...........Darn!!!............after 10 minutes of nothing happening......I decided to change brake lines around and hook the rear line to the front port and moved the bench bleeder stuff to the rear port........Started bleeding the rears using the front and it looked like a drinking fountain out of the rear calipers......so....the rear brakes lines were O.K...........switched the lines back to normal and I now have front and rear brakes.........Bingo!!!...........I'm not even gonna try and figure it out.........Still waiting to hear from Ridetech to see if their parts increased the turn radius so I can get the oil pan clearance issues resolved.......I'll call them again tomorrow.....
Ken
Old 10-29-2013, 10:06 PM
THE MONEY SHOT!! HAHAHAHAHAHAHAHA
Originally Posted by kwhizz View Post
Old 10-30-2013, 04:58 PM
kwhizz's Avatar
Now that the stupid Brake issues are gone......I took the day today and got all the Disc Brake emergency brake cables integrated into the system and it's all finished up and working perfectly........The wildwood expanding internal brakes built into the rotors are ......Lets just say a lot "Better" than the Seville rears used on the last couple swaps......Great job Wilwood!!!!...........I also started getting the console wiring made and installed .......doubled checked the Neutral safety switch and the back up light switch and everything works where and when it's supposed to......I also got the info on the turning radius of the Ridetech suspension.........It is a slightly larger turn radius than stock but they said not to worry about it.........So.......I'm not gonna worry......LOL........Time for a Nap!!!
Ken
Old 11-03-2013, 08:46 AM
kwhizz's Avatar
Started the weekend off by starting to re-install the proportioning valve back into the brake system........LOL....My K-D Taiwan built flaring tool ended up being non-useable.......I should have bought one of those good ones for $200, but I thought that this $80 one would be able to make maybe at least 20 flares.........LOL........Wrong.........Advise to anyone doing this stuff......Don't buy any of this foreign "JUNK"...........
The next thing I had to deal with was after buying and installing the "Shiftworks" cable conversion kit for the console shifter.......Everything was fine until I installed the cable to the transmission........It seems the supplied cable was a little too short and didn't have enough length to allow for the cable's bend radius......the cable came right thru the floor and had to be bent straight down to the mounting bracket and bent again to fit the trans mount........So....I ended up having a Lokar cable laying around and after installing it.....everything was smooth......I just need to make some clevis adaptors to get everything to mate together...........
The Rick's tank showed up and I picked it up with the Impala (the only car around with a trunk big enough to fit).......got it home and "Wow".......what a quality piece of work......Great Job Rick's........
Old 11-04-2013, 07:36 AM
LS7 Z/28 LS7 Z/28 is offline
Really liking this build, I'm looking forward to more. Love the '66...
Old 11-06-2013, 12:03 AM
CarlC CarlC is offline
Ken,
That tank is a thing of beauty!
Can I ask a favor please? What is the measurement from the center of the fuel module hole to the far end of the filler neck? I'm just making a database of chassis needs. Thanks!
http:www.vaporworx.com
Old 11-06-2013, 05:43 AM
kwhizz's Avatar
Originally Posted by CarlC View Post
Ken,
I'll measure when I get back from SEMA......
Ken
Old 11-10-2013, 08:20 AM
coachwinbush coachwinbush is offline
nice project keep up the good work
