Old 12-16-2013, 07:28 AM
GrabberGT's Avatar
Originally Posted by Stewbear42 View Post
The control arms are stock Moog arms with a AFCO coilover shock and a hyperco spring. The shock is mounted on the lower control arm where the strut rod mounts and the upper part of the shock mounts on the inside of the shock tower. I also have delirium strut rod bushings and a 1 1/8 front sway bar.
I'd REALLY like to see a picture of this. PLEASE?
Chris
Its not a Vega!!!!
Old 12-16-2013, 09:56 PM
65 347's Avatar
65 347 65 347 is offline
I am re-doing my front end and am interested in pics and set up also.
Mike
Old 12-16-2013, 11:09 PM
Stewbear42 Stewbear42 is offline
Mike
Snapped some pics of the car real quick. Not the best quality but hopefully you can get an idea of what I am working with up front. Excuse all the dirt and grime...
Old 12-19-2013, 07:14 AM
390 S code 390 S code is offline
Default front shocks
Used a simular setup on my fastback I replaced the upper arm with a AFCO piece with a Shelby drop . Made a custom mount which bolted up into where the old spring mount sat in the tower using AFCO shock mount welded to the removable plate ,this can be all built for a lot less than any Brand name setups .
Old 12-20-2013, 09:40 AM
GrabberGT's Avatar
Interesting upper mount placement. Heres another option that is common in Brazil on Mavericks. What do you think of this?
http://www.nhra.com.br/?attachment_id=135
Its does not show well in the photo but that upper shock mount is adjustable
Chris
Its not a Vega!!!!
Old 12-20-2013, 09:27 PM
chetly chetly is offline
I think if he does anything with the front suspension other than what's already installed he'll install more Maier Racing products being he works there.
Old 12-21-2013, 01:42 AM
GrabberGT's Avatar
It wasnt a suggestion but more of a "if you did that then maybe you might have an opinion on this...: kind of post. My thoughts are, you better have a pretty serious Monte Carlo Bar if you plan on getting aggressive with this suspension design.
Chris
Its not a Vega!!!!
Old 12-22-2013, 10:40 PM
gotcha...
Maier does make a pretty strong shock tower brace. Completely welded and bolts to the firewall with 4 bolts and under the shock mounts.
Old 12-23-2013, 09:06 AM
I have to tell you -- dude -- you're amazing! Most "kids" your age would have just torn up the car and it would have ended up on blocks in the driveway. I'm very impressed that you've stuck with it - cause it's a LOT of work and a lot of $$ which I ASSume is scarce to begin with.
Good for you!
