Old 12-22-2013, 08:29 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Originally Posted by redefined View Post
Awesome decision on the safety upgrades! Your thoughts in your last post relating to what you enjoy doing with your car is almost spot on as myself! Good looking car!
I'm thinking of doing the Heidts front and rear full kits on mine before even doing an LS swap. Can't decide though since the suspension is already started with other arms and upgraded parts!
Heck of a build, stay warm in that garage!
Thanks for the compliments! I was struggling to figure out what to do... but feel good about the choices now. I think your making the right decision to do the chassis upgrades before adding more power...good luck with your build.
Good stuff and good thoughts Dale!
#1 --- I have a couple fire suits -- Go with a lightweight version (summer driving) if you are only going to get one. My heavier duty (more fireproof) version is just a sweat box in the summer.
#2 --- I like your top speed limiting thoughts. It's good that you've felt that and know to pay attention to it. A car can get real ugly once that air gets up the car.
I think the rear end gears in the Mustang are my limiter... and as you rightly pointed out - these speeds are plenty.
I'm running a Tilton in the Mustang -- it took them three times to get it right so it doesn't squeal like a pig...
Thanks Greg... I just now noticed you changed the location in your sig to "Sun Valley", should be some awesome skiing about now. Sounds like a great place to be for Christmas
Appreciate the advice on the fire suits... right now I don't have a clue. Do you have the two piece, or one piece driver suit? After doing some online shopping I'm thinking one piece... Nomex material... either one layer or two. Not sure which brand yet.
Originally Posted by 71RS/SS396 View Post
Dale, just a heads up, we've had some problems with the bearing in that Cloyes timing set failing. The bearing is not a good match with the oem thrust plate, the hole in the thrust plate needs to be chamfered to clear the lip/ridge on the bearing, we don't use the bearing anymore, we custom machine a bronze bushing for each engine so we can get the chain tension we want.
Hey Tim...thanks for the heads up. I will pass this info along to my engine builder... I think he just purchased a couple of the sets of the Z racing stuff.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
