Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 01-29-2014, 06:36 PM
67Rally's Avatar
67Rally 67Rally is offline
Here are the quotes:
With a driveshaft loop you are pretty limited, the X has to go behind the safety loop.
And
The NHRA required driveshaft safety loop has to be within a few inches of the front U-joint. I wish I had a photo of mine to show.
I like the DR. Gas X setup, all these others are copies.
The X has to go behind the safety loop.
Old 01-29-2014, 07:39 PM
DBasher's Avatar
DBasher DBasher is offline
Learn something new everyday. Let me ask ya, if its mounted 6" off the front and the rear joint breaks would it hit the ground?
The only loop I've put on is our Studebaker and its more toward the rear. I know that where its located either end can break and neither hit the ground. Just curious.
Dan
Old 01-30-2014, 05:03 AM
67Rally's Avatar
Dan
Yes, it would still hit the ground, but it would just drag. I think the real fear is that if the front lets go, it could tear up the tunnel and anything (anyone) directly above it.
There's no reason why you couldn't run two loops. One front and one rear, but the NHRA rules require only the front one.
Old 01-30-2014, 11:10 AM
OBeer-WAN-Kenobi's Avatar
Originally Posted by 67Rally View Post
...I think the real fear is that if the front lets go, it could tear up the tunnel and anything (anyone) directly above it....
Not to mention, possibly pole vaulting the car ass over tea kettle.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-30-2014, 11:43 AM
67Rally's Avatar
Has this ever really happened?
Old 01-30-2014, 11:19 PM
intocarss's Avatar
i HAVE HEARD IT HAS BUT NEVER SEEN ONE LIVE (THANK GOD) I HAVE SEEN THE FRONT OF A DS BREAK, HIT THE GROUND AND THEN FOLD IN HALF AND TAKE OUT A REAR TIRE
THEY SAY THIS HAPPEN BECAUSE OF THE DS BREAKING AT THE FRONT IDK HARD TO TELL
@ 8 SEC
Old 02-02-2014, 03:27 PM
DRJDVM's '69's Avatar
I think Myth Busters did an experiment with trying to launch the car with a broken driveshaft....if I'm remembering correctly, they couldn't get a car to do it....
Old 01-30-2014, 11:21 PM
intocarss's Avatar
SOME CARS IN NHRA REQUIRE 2 LOOPS
Old 01-31-2014, 05:54 AM
67Rally's Avatar
I wasn't even thinking about those classes. That was me speaking out of ignorance, thanks for pointing that out.
Old 01-31-2014, 09:29 AM
NvrDun71 NvrDun71 is offline
Fighting a similar packaging issue, it seems magnaflow likes to put the x-pipe in there exhaust kits right inline where a DS loop would go per NHRA spec
71' Nova - LY6, T56
