Old 02-05-2014, 10:39 AM
Buddy z/28 Buddy z/28 is offline
Angry ricks stainless fuel tank & phantom fuel system
Has anyone installed the new areomotive phantom stealth fuel system 340 .In a rick's (rockvalley) stainless steel fuel tank? I know they make a efi fuel tank,but I ordered a crate ls2 engine from pace performance .It has a victor jr.carb.manifold and a 800cfm edelbrock car. But with the new holley termantor efi system,i want to go with I need to install aeromotive phantom stealth fuel system in this tank that is set up for a carb system.I don't know were the baffle are in rick,tank are. thanks for any help buddy s
Old 02-05-2014, 12:14 PM
Blake Foster's Avatar
it might be me but this is a very confusing post. do you have a ricks tank or an Aeromotive tank the Rockvalley makes?
Blake Foster
www.speedtechperformance.com
Old 02-05-2014, 01:20 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Not just you - -I couldn't figure it out either.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 02-05-2014, 04:36 PM
Default rick's stainless fuel tank &phantom fuel system
Sorry about the confusion. the fuel tank is the one Detroit speed sells.The narrowed fuel tank.Its for a 1969 Camaro .made by rick's. for Detroit speed What I am trying to do is install the phantom 340 fuelpump system in the tank. But I don't know were the baffle are in the tank. I don't want to cut into the tank and hit the baffles. So I was trying to find out if anyone has install this system in this tank.I want to change from a carb system to the new holley terminator efi.That is why I want to install this fuel system thanks
Old 02-05-2014, 05:24 PM
dontlifttoshift's Avatar
You don't have a Ricks tank. You have a DSE tank manufactured by Rock Valley.
If you look closely at the tank you will see ripples on the top and/or bottom of the tank where there are spot welds. Those are holding the the baffles in place. You could remove the sending unit and look in with a flash light to get a better idea.
For the most part, centered side to side, towards the front would be a good location for that setup if that is what you want to run.
Donny
Old 02-05-2014, 06:30 PM
Default rick's stainless steel fuel tank & phantom fuel system
Thanks I would have never thought of that. great idea thanks again you guy's are the best. buddy
Old 02-05-2014, 07:02 PM
Default rick's tank
Donny is there a better fuel system that you can recommend?
Old 02-05-2014, 07:16 PM
Without knowing you or the application I can not recommend the best setup for you.
I feel that Vaporworx is the best setup out there right now.
Donny
Old 02-05-2014, 10:05 PM
CarlC CarlC is offline
Thanks Donny.
We do offer a kit to retrofit modern fuel modules. If the OE's could come up with a better, less expensive, more reliable method than a fuel module, they would have done it.
http://vaporworx.com/retroworx_kit.htm
Instructions:
http://vaporworx.com/Vaporworx%20Fue...structions.pdf
http:www.vaporworx.com
Old 02-06-2014, 10:32 AM
Default rick's stainless fuel tank&phantom fuel system
Donny Here is what I have; pace performance crate engine. Pace designed a new (2010) carbureted LS engine package around GM's 6.0L LS2 engine This carbureted LS crate package twists the dyno needle to 445 hp at 5700 rpm and 444 lb-ft of torque at 4500 rpm. block; aluminum six bolt cross-bolt main caps.cylinder heads; aluminum cathedral port (ls6 type).camshaft; hydravlic roller,.500 inch lift,200/203 degrees at .50 inch lift.compression; 10.9:1.intake edelbrock victorjr. casting 2908.carburator 800 cfm edelbrock.transmission tremec tko 5 speed.rear end gears posi 3.42.headers hooker 13/4" tubes.ignition oe coils and harness.ignition module pre-programmed edelbrocks ls1 programmer. What I want to do is replace the carbureted system with the new holley terminator 550-405 EFI system.I want to put a fuel system in the gas tank. To make less noise and simpler fuel hose installion.I am putting this in a 1969 pro-touring Camaro. thanks again buddy
