Old 02-07-2014, 06:09 PM
TK442 TK442 is offline
Originally Posted by Bigbore500r View Post
If you are going external pump, the newer Holley EFI pumps are awsome. Totally silent, even when mounted straight to the frame. Your stock tank will have issues when fuel level is lower, during hard braking or turning. If that bothers you, I would look into a new tank and at that point do an in-tank setup since you are replacing the tank anyway. Aeromotive makes a drop in unit that installs where a typical sending unit is
Ok thanks I didnt see the drop in unit from them but I see their fuel cell set up I thought that was a good clean look. Which way would you go?
