02-01-2014, 01:08 PM
Thanks for the photos Blake. Although the mounting bracket looks different, i do not think it was modified in mine or I can not think of a reason that required any modification.
Anyways I guess I need to flush out the ATF, don't know how though. Also a new rack and pinion maybe necessary
72 Camaro RS:SOLD
68 Camaro:
02-07-2014, 10:05 PM
I would drain the reservior and fill with PSF. Run it for a few miles and change again
02-08-2014, 12:32 PM
Thanks man for the input, will do that
72 Camaro RS:SOLD
68 Camaro:
02-10-2014, 10:07 AM
Rack and pinion leak update!!
Ok guys I am going to order the 2GMP control valve as per Blake's advice. As for the Banjo fitting leak I did put littel force on the Banjo fitting, and it seems like it did stop the leak.
However, my concern is the leak shown in the first photo, apparently the black round cover is a plug to prevent ingress of dirt into the pinion portion. My interpretation might not be right and appreciate if someone could chime in to educate me.
With above being said, does it mean that a new rack and pinion needs to be installed or I can remove the black cover shown in the first photo and tighten the nut ( if there is one)
72 Camaro RS:SOLD
68 Camaro:
02-10-2014, 10:38 AM
If I were you I would Call Mavel manufacturing and ask DIRECTLY.
talk to Marc Mercurio,800-338-9080 tell him I gave him your number.
02-10-2014, 11:34 AM
Thanks Blake,I will give him a call sometime this week
72 Camaro RS:SOLD
68 Camaro:
02-10-2014, 06:24 PM
Fyi dse has the flow valves in stock
02-10-2014, 06:26 PM
02-11-2014, 04:59 AM
Thanks man. The DSE control valve is applicable to PS pumps with integrated reservoir, whereas the Billet Specialities RP1300 is intended to be used with PS pumps with remote reservoirs.
I have remote reservoir so the Billet Specialities valve will be the correct one for my application
72 Camaro RS:SOLD
68 Camaro:
