Old 02-25-2014, 09:33 PM
The car is looking good nice to see you posting over here.
Old 02-26-2014, 06:42 AM
rickpaw rickpaw is offline
Looks good.
Do you still have the old set of 17" wheels?
Tu Ho
Old 02-26-2014, 07:19 AM
dipren443 dipren443 is offline
That is a lot of work!!!! Looks good so far....did you install the DSE rear or did G-force?
G-Force installed the rear, roll bar and painted the underside.
A friend and I are responsible for the front suspension fab.
My dad and I painted the firewall and subframe in my garage.
Thanks Wayne!
Originally Posted by rickpaw View Post
Looks good.
They were sold a while ago. I still need to order the new fronts, but that isn't top priority at the moment.
Old 02-26-2014, 09:32 AM
Some random pics from the recent reassembly process.
Motor/trans dropped in
Lug nut selection... You guys feel free to comment on which you'd prefer as I would love your input. The hub pad on the wheels is rather thick. The lug nut on the right is longer than a standard open ended unit. The one on the left is an off the shelf piece from race shop.
Custom bracket made to hold prop valve and clutch reservoir
Prop valve and front brakes plumbed
Battery Mount installed
One rear tire sitting next to tires for my Subaru
Tire fitment tool for determining proper offset for rears
Wheels mounted!!!
Old 02-26-2014, 01:12 PM
Those wheels and tires look sweet!
Old 02-26-2014, 02:42 PM
Thanks! For now, I am sticking with the vintage SCCA Trans Am theme. May end up with track rubber later on and if that is the case, I am getting something light. However, I will still keep the Minilite reps for the street.
Old 02-26-2014, 04:20 PM
Ok, almost to the end of the most current pics.
Here are the wheels mounted. The back of the car is overexposed in some of these to attempt to expose the wheels (needed another flash ).
It is funny, with no contrast in this pic, the 335's look kinda narrow.
Old 02-26-2014, 04:36 PM
More random pics
G Braces mocked up and mounting holes drilled
Anvil deep inner fenders
You can see the ceramic coated stainless works headers in these pics too
Old 02-26-2014, 04:41 PM
Couple pre incident pics...
Day the car came home from the previous (and original) owner
Just before the all of the bad stuff happened to the car
Old 02-26-2014, 04:50 PM
Couple more random shots as I browse through my Picasa
Rear brake line fab
