Old 03-21-2014, 07:50 PM
TimeWarpF100 TimeWarpF100 is offline
Originally Posted by Rod P View Post
you can run the 66 with a newer motor....we all do.... I run my 1968 camaro with a 2007 LS motor
Thanks Rod!
I guess I did not make it very clear.
Because there is no stand alone harness available for the 3.5TT I have to keep the electronic assist steering, ABS, Roll Control, Stability control intact as there does not seem to be a way around it. After watching many runs in Scottsdale a week or so ago I was surprised at the number of cars that were locking up a single wheel or just 2 wheels going into a turn. I started project 2yrs ago in April but now looks like I will not be able to run.
Can I still run it? I thought I read no ABS etc allowed.
Just trying to figure out which class if any I could run in.
Old 03-21-2014, 07:57 PM
here is where I am at right now. Illness has caused a 2yr hold on project but really want to get back on it soon.
Complete bare frame shipping weight is 520lbs
Old 03-22-2014, 06:06 AM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
Originally Posted by TimeWarpF100 View Post
Thanks Rod!
I would Guess the car would be nicer to drive With all the original Equipment, but maybe the Stability Control and such would work "weird" in a differnet car than programmed for?
There is a lot of stand alone engine management systems to choose.
Electromotive - USA
Haltech - Australian
Autronic
Motec and probalby more, but these are the one i remember right now
Megasquirt too!
I think Motec and Autronic are the most "fancy" and pricey, but they all are mostly the same but with different "extra-abilities" built in, as running turbo-lag Control and whatever. Now they probably all are the same.
Electromotive can be very simple if you want it to be, a friend has a turbo VW With only MAP, TPS and TEMP that is all! You could have much more if you want though. Haltech I have also heard are Nice and easy to work With. I have not owned any myself. But look up their homepages
Old 03-22-2014, 07:27 PM
Electromotive - USA
Autronic
Megasquirt too!
Only one of those companies makes one. MegaSquirt. But for a price between 10,000-12,000.00 just to run the engine think its a bit much. I can do half the truck for that amount. I was hoping to do the complete truck DONE for around 25k or less.
At this point I will have to keep going with the stock Ford Computer's.
I "think" I have that portion figured out.
I was trying to find out what I needed to do to be able to run Auto-X.
The stock ford computer will not know what vehicle it is running just that it will be a bunch lighter.
Old 03-23-2014, 12:07 PM
Where did that price come from? I would Guess like 2000-3000 maybe for an Electromotive. Haltech is maybe around the same. Megasquirt is cheaper, Motec on the other hand can probably end up expensive if you want to.. I think the hardest part to Control would be the transmission maybe?, the stand alone units can work inbetween Stock Control units.
But I see now that you are using the Complete frame from the newer car, so then it would probably be easier to use it as is. Just "bolt-on" a New body (Sort off.. )
And end up in that class you end up in.
Old 03-23-2014, 07:43 PM
silvermonte silvermonte is offline
You may not be able to run in a GG in a timed matter, but I would bet there are plenty of other places to run autox that wouldnt give two hoots what you have, and would just be glad you showed up to have fun.
Old 03-23-2014, 07:58 PM
Having no time to compare what others are doing would take out half the fun . .
Old 03-23-2014, 09:13 PM
They would time you, but you would be considered exhibition and you wouldnt be eligible for prizes. Would be the same thing as showing up with tires lower then 200 tread wear, or any of their other rules to keep things fair.
Old 03-23-2014, 07:57 PM
Because its such a complex system having Twin Turbo's and direct injection nobody messes with it. I called and got a price. that is some serious $$
