Old 05-02-2014, 10:16 AM
carbuff's Avatar
carbuff carbuff is offline
Ohhh you did eh? I recall you had a steering issue but did not see you replaced it. Did it fail completely or you simply decide to upgrade/change?
I did. The original rack blew a seal for some reason while at the Fall Fort Worth GG event, and I was leaking fluid all over the place. So I replaced that with a remanufactured unit from Pep Boys. For some reason, that rack never 'felt' right to me. Sloppy, a bit too soft. So I started hunting around for different options and ended up with AGR. I ordered one of their 'stock replacement' units from Summit. They can do all sorts of customizations, with perhaps the most interesting being the internal spring that affects the feel of the rack.
I've been happy with this one. No leaks, no slop in the feel, all around works well. The original one was fine also, just sprung a leak. :\
Old 05-02-2014, 10:18 AM
Leroy Rochester's Avatar
Leroy Rochester Leroy Rochester is offline
Looking bitchin! You guys are hustling on this thing. The totality of my progress over the last month has been turning it around in the garage so I can stare at the back end instead of the front end for a while...
Old 05-02-2014, 12:30 PM
sik68's Avatar
sik68 sik68 is offline
Awesome! But I can't unsee the
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 05-02-2014, 05:44 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
That's going to be the look on Dave's face when he gives it some jandal for the first time, lol.
Looking good guys!
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 05-04-2014, 08:52 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
lateral-g
Old 05-05-2014, 08:19 AM
Ron Sutton's Avatar
Looking good guys. Nice progress.
Ron Sutton Race Technology
Old 05-05-2014, 10:03 AM
Those numbers are a pleasant surprise.
Of course Rob refuses to believe them. Even though they are from his scales.
Old 05-05-2014, 11:53 AM
yes, nice weight...lets see how much you get at race weight.
Old 05-05-2014, 12:04 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
Funny Dave, my Mustang was within 50lbs. of that, when in a similar state. Car ended up at 3160lbs. At least that is what it was before I got crazy and started installing creature comforts like side glass, wipers etc. Figure you'll end close to the same, liquids are heavy.LOL
Old 05-05-2014, 01:00 PM
Looking good guys!
Jon
Haha I never noticed. Thanks, now I can't unsee it either.
I would be STOKED if we came in somewhere around your 3160. Although this thing does take darn near 100 lbs of oil.
