Old 05-03-2014, 11:09 AM
dennism dennism is offline
Default changing from points to electronic
Question for ya'll...I have two wires going to the existing coil, but no resistor as far as I can tell. When I change to the new coil, do both those wires connect to the positive terminal?
Old 05-03-2014, 01:34 PM
camcojb camcojb is online now
Where do these wires go now? Should be one on the negative and one (or more) on the positive.
Old 05-04-2014, 06:29 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
You need to provide more information, what specifically are you installing? I assume instructions were included with the product you purchased, you might consider reading them.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 05-06-2014, 06:09 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Originally Posted by TheJDMan View Post
You might consider reading them.
Lol!!!
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 05-08-2014, 10:59 AM
Default points to electronic
Thanks, I wasn't totally clear on this. There are two wires to the POSITIVE terminal, and I'm wondering if one is a resistor. I don't have an ohmmeter to check on them, and I've read the instructions carefully, but I'm confused by the section on the gap. How is that measured?
Old 05-08-2014, 12:01 PM
You need to borrow a voltmeter and check the voltage coming in, key on. I don't know what electronic system you're converting to, some require the lower voltage of a point system, and even include a ballast to use; others require a full 12 volts to operate properly.
To answer your gap question I'd need to know what system you're using.
