Old 06-09-2014, 08:56 AM
With a LS9 and a E67 controller, ABS brakes, Vintage Air, Stereo, Stack Data Logging dash and Vapor Work fuel controller; there is a lot of wiring. It is just easier to do it from scratch. We have ever connecter defined for that pin is what function, color of wire and gauge. We copied a Corvette ZR-1 for wire colors and sizes. We can trouble shoot the system with a GM Tech 2 and the factory wiring manual. Some of the connectors are hard to find but over the last couple years Ryan has found them all. He does like MIL Spec connectors which drive the price up a bit but allows the engine or other harness to be removed from the main body harness.
To get all the wire in the correct gauge and strips Ryan had to order some of it custom. A bit over kill but it is nice to have the OE wire style and color coding.
"If it is worth doing it is worth over doing"
Mark
If you have the ability and tools to do it, it's the only way to do it right.
Where do you source your wire?
Old 06-09-2014, 09:13 AM
Stielow's Avatar
Stielow Stielow is offline
We had Wyetch and Terminal Supply quote the order the used the two quotes to get a better price. We ended up getting the wire from Terminal Supply in Troy MI to save shipping.
Old 06-09-2014, 10:10 AM
thank you Mark.
Old 06-10-2014, 04:02 AM
Keithq68 Keithq68 is offline
Does he post as BlackPenquinn on LotusTalk??
Yes that's him Greg.
Mark, would Ryan sell me a connector for the Delphi ABS module?
If so, could you post or PM me his contact info?
Keith Quinn
Old 06-10-2014, 06:48 AM
RussMurco's Avatar
RussMurco RussMurco is offline
Speaking of wiring Ryan Kuhlenbeck and I are on our 4th version of wiring. Ryan is the brains behind the wiring and has it sorted out. We are wiring this whole car from scratch. Wire of spools, no kits. Our own fuse boxes and power distubution system.
We will build the engine harness then dyno with its correct harness.
Mark
I'm obviously not an engineer so I'm just trying to comprehend how much time it would take me to plan-out a complete wiring system, starting with just wire, a fuse box, and a bunch connectors... I'm guessing a full week of just drawing the schematic, another week to plan-out routing, probably 2 weeks to install all the connectors, and another full week for complete installation! I cant say it doesn't look like fun, though! Any tips you feel like posting for this part of the project will be much appreciated, Mark!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 06-10-2014, 06:55 AM
fleet's Avatar
fleet fleet is online now
In other news...wire stocks rose.
Old 06-29-2014, 11:31 AM
next69 next69 is offline
Mark, if your car already has provisions for wheel speed sensors what would be a good cost estimate to install ABS? I know you need wheel speed sensors, some sort of controller and some wiring. I am surprised no one is offering a kit yet, at least that I have seen, my guess it is a concern of liability that is preventing a retail solution.
Keep up the great work, cant wait to see the next update.
Old 06-30-2014, 03:16 PM
The T-man The T-man is offline
wow...
Old 07-04-2014, 06:41 PM
Z06Joe Z06Joe is offline
Wow indeed!!! You guys have got your work cut out for you!!!!
Old 07-04-2014, 06:59 PM
Stielow's Avatar
Engine harness is done. Working on body harness now.
Mark
