Old 06-11-2014, 08:53 AM
syborg tt's Avatar
What are the options for 335/30 18 tire with matching 265/35 18 for primarily street driven car?
BFG seems to be the go-to tire
marty-mj
Old 06-11-2014, 10:24 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
265 Rivals are not (quite) available yet. They were due out early spring but have been pushed back to July last I heard. I had a set on order and finally caved and went with Bridgestone RE11's in the front. Hopefully they will have them available soon.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 08-01-2014, 12:58 AM
68LS1's Avatar
68LS1 68LS1 is offline
Well the boys did some construction work on the shop and built the Camaro it's own little room
Right quarter now on permanently, left quarter and drop off removed, left mini tub in place. going to look like a car again very shortly.
QUADRALink, Moser 12bolt, Vaporworkz tank, Magnum T56, LS9 Clutch have all arrived
Subframe, Kore3 Z06 Brakes and some smaller parts on the water now, due here in next 2 weeks.
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
The Following User Says Thank You to 68LS1 For This Useful Post:
syborg tt (11-26-2022)
  #34
Old 08-01-2014, 06:04 AM
Rick D's Avatar
Rick D Rick D is offline
Looking nice Rodger, what qtrs did you use? I need to maybe change (haven't decided yet) one of my, I just build a new lower section.
Rick
Old 08-01-2014, 04:51 PM
68LS1's Avatar
We used AMD quarters, panel beater was very happy with the fit.
All the AMD stuff has been a good fit. The only bits, outer cowl & trunk drop offs, that I couldn't get from AMD, had fit issues.
Roger
Old 10-10-2014, 05:52 PM
Jon Clough's Avatar
Jon Clough Jon Clough is offline
Hey Roger,
Great progress! I have a 70 Camaro that needs all of the stuff you are going through too and have a mountain of parts. It is great to see a thread with progress, great photos, etc. Your comments about fitment are appreciated.
I have the DSE tubs, AME front and AME rear triangulated 4-bar to do too. My plan is to pull off the quarters, put in the DSE mini's, put in the new quarters, put in the new tailpan then tackle the rear subframe and floor rebuilt after the body work. Let me know what you think of the order of things based upon your experiences.
Best of luck with it !!
Old 10-10-2014, 06:04 PM
hey Roger -- what's up man!
Old 10-12-2014, 10:10 PM
68LS1's Avatar
Originally Posted by Jon Clough View Post
Hey Roger,
Tailpan was very fiddly. If yours can be repaired I would go that way. If not make sure it is identical to the one you remove, check where fuel tank filler joins and outer trunk floor brackets.
We did it one side at a time, just felt it would maintain better rigidity and we had the other side for reference.
Hi Dave, just so busy, how you doing? Send me an email with any news.
Camaro needed some parts that we thought could be used, and has been a little slower than hoped for. Pulled engine down for refresh but found some things we didn't like. New pistons, cam and some other pieces, you know the drill.
No USA/SEMA trip at this stage . Two large work projects were delayed from October 1 to November 1 launch.
Trying to spend time at the cabin on the river, just back from 4 night stay which was super nice.
Roger
Old 02-28-2015, 07:42 PM
68LS1's Avatar
Well some progress. Body shell has all panels replaced and final welded, and is sprayed in epoxy primer.
DSE subframe also now fitted
Hopefully all front panels and doors will be installed, and it will go off for installation of, QUADRALink, diff, engine, transmission, subframe connectors. This will conclude required cutting to floor.
Then will continue with assembly for mock up.
Also was able to collect wheels from shipping company yesterday.
Forgeline RB3
Front - 18 x 9.5" with 5.875" backspace
Rear - 18 x 12" with 8" backspace
Satin black Centre with brushed hoop
Rear tires due here Tuesday, so will get fitted and will be ready for test fitting with diff.
Still need to get radiator, decide on front drive and intake.
Roger
Old 02-28-2015, 08:07 PM
Che70velle's Avatar
You've been a busy boy! Looks great. Love what your doing here. My next project will be a 70' camaro. Keep the pics coming.
Thanks Dad!!
