Old 06-22-2014, 07:52 AM
jwcarguy jwcarguy is offline
Banned
not sure on the fitment of the Camaro oil pan
Which pan are you referring to? the earlier 98-02' F-body oil pan
or the new fifth gen Camaro oil pan
If the issue is at the "front" of the sump, the earlier Camaro pan is approx 2" shorter
I may be interested in the vette pan for a future build also
here are some pics with dimensions:
Old 06-22-2014, 11:27 AM
Not sure jake said camaro pan works but not sure if that means gen 4 or 5...
You are first dibs on pan if you wan it.
Old 06-22-2014, 11:38 AM
Banned
my guess is he was referring to the standard "f-body" oil pan (98-02')
since you can see in the pic that it is only 11 1/2 long in the sump, rather than the 13 1/2" on the Vette pan
The 5th gen Camaro pans are deeper and are as long as the Vette pans
I use the Vette pans on sand rail LS swaps
here is my Desert Dynamics car
( the muddy one, is after it's maiden voyage with the new engine I built and bigger transaxle, so much for a "Dry Lake Bed")
Old 06-23-2014, 04:36 PM
Anyone know if the wind age tray is the same between f body (2002) and corvette
Old 06-24-2014, 10:07 AM
Gabe @ G-Rodz Gabe @ G-Rodz is offline
Each oil pan has its own windage tray. They are not compitable....
