Old 07-18-2014, 05:27 PM
fillpot fillpot is offline
Default Firewall bulk connectors
Guy's finishing up the last of my wiring and just mounted the battery in the trunk and was wondering if ya'll used this type of connector to get to the stater, engine bay etc, and where did you go threw at,pics would be great if possible. THANKS!
Old 07-18-2014, 09:52 PM
fishface's Avatar
fishface fishface is offline
Haven't used one but saw a writeup in Camaro Performers on this. They used a Moroso Thru-connector and went through the toe panel on passenger side. It put the cable at the proper angle to eliminate sharp bends etc. A little safety tip they also included is to put a rubber boot over the exposed studs after attaching cables. Hope this helps and gives you an idea.
Old 07-18-2014, 10:41 PM
I like to use the Moroso bulkheads too.
Old 07-18-2014, 11:00 PM
I have a question why is the negative pass through insulated like the positive ? If it wasn't wouldn't it be another grounding point? Or am I missing something??
Old 07-18-2014, 11:07 PM
For grounds I just use a 3/8" bolt. From the battery to the frame, crossmember to the trans, two engine to frame.
I agree, its a waste.
Old 07-19-2014, 06:13 PM
Thanks guy's that's about the same spot I was thinking of. THANKS AGAIN!
