Old 07-26-2014, 08:48 AM
Default Something looks off QuickTime help needed
Are people using the engine plate for their QT bbellhousing on. Ls/t56 combo?
Asking because with on OEM starter and an OEM f body pan the block plate seems to interfere with the starter and rubs tight on the pan
And I have starter interference with the bell crap so much for "designed to work with OEM starter"
I hate cutting new parts up to make them work #%^*¥
Should I ditch it?
Old 07-26-2014, 12:31 PM
Should I ditch it?
yep, some trimming necessary....what part number do you have?
Old 07-26-2014, 01:39 PM
Summit Racing Part Number:QTI-RM-8020
Looks like both the engine plate and the bell itself interfere with starter.
Old 07-26-2014, 07:02 PM
sd67 sd67 is offline
I will probably have the same problem, it would be great if you could post a pic of the modification. Thanks
Old 07-27-2014, 06:30 AM
Will do!
Old 07-27-2014, 12:31 PM
What starter are you running? Is it the snout or mounting block on the starter thats hitting?
Old 07-27-2014, 03:17 PM
ACDelco 12617229 Starter Assembly
Snout I think
Old 07-28-2014, 06:35 PM
Josh@ottp Josh@ottp is offline
I have installed 2 now and they both needed major grinding to fit around the starter. They also required some clearance for the bleeder screw on the slave. Make sure you check that before you get it in the car.
Old 07-28-2014, 07:13 PM
Yep looks that way last thing I wanted to deal with more fit/quality issues
If you have any pics please share
