Old 08-06-2014, 12:41 PM
Awesome results and perfect for a car that gets driven regularly. Great power from that TVS2300! Congrats again and looking forward to some track times if that is in this car's future!
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 08-07-2014, 05:24 AM
69x22's Avatar
69x22 69x22 is offline
Awesome! Nothing like a supercharger.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 08-07-2014, 06:05 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by Gambit View Post
Nice work!! You got any more info on the car or a build thread I can check out?
What he said ^^^^!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 08-07-2014, 09:05 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Originally Posted by OBeer-WAN-Kenobi View Post
Nice!
That's what I want to do with my LS1 when I have the money. My biggest concern is trying to work out what kit to buy and how to use most of my current accessory drive. My accessories are stock 2004 GTO but with a Kwik Performance high mount A/C bracket on the passenger side.
A TVS2300 (6th Generation) won't work on your application at all. The problem is on TVS superchargers, the cylinder head port is based on LS9, L92 or LS3.
The difference between LS9 and (L92/LS3) heads is the type of material. LS9 heads were designed to handle higher boost, because they used a different type of material. Can you install an LS9 head on LS1 block? No. The bore size is smaller on LS1 as compared to L92/LS3.
I do have a complete Harrop TVS2300 with Wegner accessory drive and all the accessories for sale, but it is for an L92/LS3/LS9 port. Yes, it work in 67-69 Camaro. I switched to LS9 Supercharger setup. The Wegner accessory drive has 2 different sizes of pulley. The small pulley is designed for engines that have custom forged pistons, crank, etc. I tested mine at 15psi in 2009. While the larger pulley is designed for stock engines. 8 psi.
Magnacharger did design an LS1 TVS2300 supercharger kiit. The kit is described as a Hybrid TVS2300, but Magnacharger must have modified the kit with different ports. That kit is only 6psi.... If you pulled this from another car, then it is better to build around a fresh engine.
Jeff
Old 08-07-2014, 10:58 PM
Sparks67's Avatar
Good Results on the TVS2300 LS3 engine.
Jeff
Old 08-07-2014, 11:35 PM
CarlC CarlC is offline
Definitely max'ed out on the fuel pump at that power level. It's time for a CTS-V and a PWM controller.
Very nice setup. Magnuson cars are a riot to drive.
http:www.vaporworx.com
Old 08-09-2014, 11:51 AM
Josh@ottp Josh@ottp is offline
Jeff
Jeff
Just a little fyi but Harrop does make the 1900 and 2300 TVS units for a cathedral port head. The only style TVS they make that doesn't work on that head design is the new FDFI style.
Old 08-10-2014, 12:48 PM
Sparks67's Avatar
Originally Posted by Josh@ottp View Post
Jeff
Josh,
I didn't look up Harrop, when I posted the reply. The poster main concern is cost, and he has 2004 GTO LS1 (pullout). The stock accessory drive won't work, so he has to get an accessory drive that will work. Wegner never developed for TVS2300, only LS3 and LS7 engines. One thing that I am glad that I did on my LS3 engine was the oil squirters, because I wanted my engine to last.
Jeff
Old 08-11-2014, 08:32 AM
OBeer-WAN-Kenobi's Avatar
Haha, I'm a cheap SOB. A new engine would definitely be out of the question. I might start building an engine at some point in time but not now. I don't have the money to get a supercharger at the moment anyway. BUT I am trying to make sure that if the right used deal comes up I'll know what will work and what won't.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 08-11-2014, 01:20 PM
67Rally's Avatar
67Rally 67Rally is offline
Originally Posted by MattG View Post
The engine idles at 750 rpm, drives perfectly and on my drive home today to Northern VA, I managed 23mpg on a 225 mile trip from a car with roughly 760hp!
I can't comprehend having that much hp on tap and keeping my foot off the "go" pedal long enough to get that kind of mileage. Great restraint on your part, and a very nice looking setup!
