Old 12-01-2014, 05:54 PM
badazz81z28 badazz81z28 is offline
Default VaporWorks Suppose to have Baffles?
My Rick's Vaporworks tank doesn't have baffles as compared to my non vaporworks tank. Is this how its supposed to be?
Old 12-01-2014, 05:56 PM
spacepirate spacepirate is offline
I'm not sure but where did you purchase it? Is their a possibility of it being a counterfeit part?
Old 12-01-2014, 06:56 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I haven't seen the inside of one, but if it uses the gen 5 Camaro pump assembly I think its a baffle in and of itself. That coupled with the 2 remote pickups in each corner is likely all that is needed. All of the factory GM tanks I have seen on the inside don't have a baffle. This is purely me speculating, but I'm sure you should have an answer from someone in the know here on the forum shortly.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 12-02-2014, 04:41 AM
dhutton dhutton is online now
This is what I was thinking too but I googled images of the Vaporworx tank and it shows two baffles...
Old 12-02-2014, 06:27 AM
I'm pretty sure Mine doesn't either. I noticed the same thing when I was installing my pumps.
I'm sure Carl will chime in here in a bit.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 12-02-2014, 07:13 AM
It's a legit tank, I bought it from MCB and was drop shipped.
Old 12-02-2014, 07:40 AM
CarlC CarlC is offline
Gents,
No baffling is needed for the VaporWorx fuel module design. There will be bulkheads where the tank straps surround the body shell.
With the module and corner pickup arrangement the tank will be truly empty when it's out of fuel. Several members have run out fuel on-track due to the tank running dry. The setup is so effective that many folks simply forget about the fuel system.
http:www.vaporworx.com
Old 12-02-2014, 07:44 AM
Originally Posted by CarlC View Post
Gents,
Thanks Carl, appreciate the input.
Old 12-02-2014, 09:30 AM
Gents,
Mine doesn't even have those. Its a complete open tank with the little tabs on the inside for the pick-ups
Old 12-02-2014, 10:18 AM
Here is a pic:
http://www.mattsclassicbowties.com/c...-us/d2608.html
Maybe the tank has been cost reduced...
