Closed Thread
Old 01-05-2015, 10:15 PM
Nativefx Nativefx is offline
Given that it's a stroked LS2, what kind of tq numbers are you expecting and at what rpm range? How long ago was it completed and is it basically a long block (no harness, accesories, etc)?
Is there enough vacuum for power brakes?
thanks
Old 01-06-2015, 08:17 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
thanks
In similar engines I see approx 450 at around 3000 and no issues with vacuum booster.
Needs Intake, rails, injectors, TB, coils and front acc. I have stock LS2 rockers and stands but no pushrods.
Will ship for FREE to lower 48
  #13
Old 01-09-2015, 09:17 AM
Corey R. Corey R. is offline
Pm Sent.
-Corey
  #14
Old 01-09-2015, 04:05 PM
Vega$69's Avatar
Deposit Received
  #15
Old 01-09-2015, 04:18 PM
califconstruct's Avatar
califconstruct califconstruct is offline
I can honestly say, that pricing had me thinkin' about it!.
  #16
Old 01-10-2015, 10:46 AM
jwcarguy jwcarguy is offline
Banned
Guess that you won't be needing the set of hardened 7.400" .080" pushrods and full set of LS2 rockers and stands that I pulled out for you early this week??
Jeff
  #17
Old 01-12-2015, 02:12 PM
Jeff - I am the one picking up the motor from John. I may be interested in the rods of they are the correct length. Let's touch base after John and I finish.
  #18
Old 01-12-2015, 02:20 PM
Banned
Corey
John already picked them up from me over the weekend
Jeff
  #19
Old 01-12-2015, 02:24 PM
Vega$69's Avatar
Originally Posted by jwcarguy View Post
Corey
Jeff
I bolted up the rockers and the stands. I did not install the pushrods. Need to check with a pushrod length tool to confirm they will work.
Closed Thread
