Old 01-15-2015, 08:59 AM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
Since the column is in the same place, and the a-arms and rack should be as well, there's no reason it shouldn't work with Scotts subframe. Only issue I can see is that his A-arm mounts are taller than mine. If you look early in my build thread you can see more details without the sheet metal and all in the way.
No Shop, No Money, No Time.... No problem!
Old 01-15-2015, 09:24 AM
Sonar Chief's Avatar
Cool
I'll check the angles and such later today .... these Unisteer joints are huge compared to the Borgeson's joints, I may switch them out to gain clearance!
Old 01-15-2015, 04:24 PM
efs69's Avatar
efs69 efs69 is offline
Not sure if this will help you but here is my similar frame with Unisteer. I was able to remove the rag joint mount from my tilt column and used a Unisteer adapter. My rack isn't tilted.
Old 01-18-2015, 08:02 AM
Steve68 Steve68 is offline
Looking good chief!!!
Beach cruiser, you don't have a lock washer or any washers under the nuts on your upper control arms, why not?? aren't you worried about those parts coming loose?
Old 01-18-2015, 08:05 AM
He's using Nylocks
Old 01-18-2015, 04:27 PM
Smile Update 1/18
Thanks for the pixs guys, I do appreciate all opinions!
Not much to show today, as far as the Camaro that is .... spent this weekend putting up rigid insulation for a ceiling in the garage (tired of freezing my ... off!) came out nice still need to tape the edges.
My buddy and I pulled the subframe (w motor and tranny ...Uggg) forward to get my subframe connectors in, PITA Should have pulled the engine combo first, oh well it in and I'm tired of working w that Styrofoam stuff, what a mess that was, I want to work on the Camaro for awhile!
Its brighter too w the reflection.
They are in, still need to push them back flush and get the welder out and make some heat!
I'm gonna go and work on the Camaro now ... no more insulation stuff, supposed to snow tomorrow too, perfect timing!!
Thanks for comments guys .....
Old 01-20-2015, 06:25 PM
Smile Turn up the heat ...
welding generates heat! So I worked on getting the subframe connectors lined up and snug .... (a little anal retentive) I had to open one side to get the subframe to line up with the rear frame rail and left a gap on one side, grrrrr.
Well I got the connectors in and welded to the floor, still need to attach the seat metal to the floor, waiting on warmer day to spray some epoxy under the seat frames.
That's all I have for today, that actually took longer than I thought it would ... , but it's done!
Thanks for looking ...
Old 01-20-2015, 06:41 PM
Build-It-Break-it's Avatar
Any progress is good . Looking good chief.
Ahmad B
Old 01-20-2015, 07:24 PM
Roberts68 Roberts68 is offline
When you say you had to trim more and it left a gap on the opposite side how thick was it? Did you have to put a filler strip in there or just lay a fat bead?... Or overlay a little with the bead?
Did you feel comfortable aligning and working alone or did you have some help? I remember you mentioned having a buddy doing the bull work but wondered about the measure twice and weld once parts.
Old 01-20-2015, 08:30 PM
Cool
Thanks, wished it was summer thou!
I had to shift the passenger connector over in the back to align w the rear rail, yes that left a gap on the outside, I used a copper backer and laid down a wide bead .... slowly!
I always work alone, I had Tom come over to muscle the subframe and help take cross measurements (hard to hold both end of the tape measure myself) and today I double checked everything w my laser level and had to fix the angle of the dangle. I didn't get the template exactly square, that the only thing I could think of .... so I fixed it!
Thanks for asking ....
