Go Back   Lateral-g Forums > Technical Discussions > Man Caves
Old 02-06-2015, 03:39 PM
BAD ASS STEVE!! Wow that looks nice!!
Some experience I'll share -- when painting a larger area like that.... Get some Home Depot or Lowe's 5 gallon buckets -- and get a 5 Gallon bucket screen sold in the paint department -- it hangs in the bucket.... and you run your roller against it. #1 -- carrying and moving around a 5 is so much easier -- and you can dip and roll so much faster because the bucket is more stable and the screen is "near vertical" so the bucket (or in your case the pan) isn't being pushed around.... #2 -- the bucket holds more paint so you're not constantly filling it. #3 -- if it's a multi day paint job -- you just leave the paint in the bucket and cover it with a DAMP towel.... Put your roller in a zip lock bag - seal it and stick it in the freezer --- just take in out of the freezer a few minutes before you'll start again. Don't handle the roller just unzip the bag grab the roller using the bag as a glove and slide it on the cage..... #4 -- Don't clean your cut brush either - fold it nicely in tin foil - to hold the nice brush shape - and slip it in another Zip lock bag - stuff this in the freezer too.... take it out when you want to use it again.
Figure you may be painting other rooms in the house -- so thought I'd toss in a couple pro's tricks. LOL
